compression question?
Old May 7, 2011 | 09:48 PM
evilution09's Avatar
I am wondering how big cams affect base compression. I am running 272 kelford cams and i have been told that the overlap on the cams could cause a low compression reading. anyone run into this ? and what should the compression be. I have a fully built 2.0 with 9.0 to 1 J.E.pistons car still made 519whp with 115 PSI compression across the board
Old May 8, 2011 | 01:17 AM
testa corse's Avatar
im running cosworth 272 cams and 8.5:1 C/R i read 140psi compression. Do you know the kelford's degree of the intake valve closing?
Old May 8, 2011 | 04:40 PM
Kelford spec sheet says intake closes 63degress ABDC
