Amsoil introduces new Z-Rod high ZDDP oil line
Old May 10, 2011, 08:40 PM
  #31
SmurfZilla's Avatar
Originally Posted by apagan01
Summer time above 85f, i reccomend Z rod 20W50 or AMO 10W40
Racing Dominator 15W50 for breaking the motor in
Can you PM me a quote on how much oil I need to break the motor in and then a case of the good stuff going forward. GA's spring, summers and fall are usually over 70+....in the height of summer they are 90+. Winters are typically 50's......sometimes as low as 20 (very rare). I run E85 99.9% of the time although I do have pump gas "limp home" map.
Old May 10, 2011, 08:49 PM
  #32
wizzo 8's Avatar
Nice. Hopefully Fp updates there recommended oil list and adds this oil to it.
Old May 11, 2011, 12:48 PM
  #33
Dallas J's Avatar
Whats the price for a case to us?
Old May 11, 2011, 06:55 PM
  #34
BURNALL_4's Avatar
+1 Zrod 10w-30
Old May 12, 2011, 07:31 AM
  #35
EvoDan2004's Avatar
Dan the RD 15W50 has very small amounts of detergents and should not be let sitting or ran for long periods, matter fact its safe to drain any race oil soon 2-3 months or 3k,,, if you are dumping the oil fast then you dont care
the Z rod oils will have all the racing oils has plus all the detergents and dispersants for a car that drives on the road
i do an oil change about every 500miles or less. and def does not last more then a month.
should i still change to the new Z rod line of oil? i will still drain it as often because i have serious brain issues. lol i just would like what is better and better protection for the motor.
Old May 12, 2011, 10:54 AM
  #36
apagan01's Avatar
Nothing wrong with being picky Dan, if it gives you piece of mind, i know i am the same way.
If you dont ming spending extra $ then dominator 15W50 is still good for you specially with your car set up, if you want to save some cash then i would go to the AMO 10W40, these both are high zinc and phos oil well over 1200 PPM on both zinc and phos
Old May 18, 2011, 05:22 AM
  #37
apagan01's Avatar
yep
Old May 18, 2011, 07:04 PM
  #38
wally7714's Avatar
Thanks for recommendation Andy. I`ll take some of Z Rod 10W30. I`ll be putting new turbo in this weekend so I`ll try to get 5 qt locally but pm price for the case.
So with my set-up and driving style you`d recommend Z Rod over Dominator ?
Old May 19, 2011, 05:02 AM
  #39
apagan01's Avatar
Correct , because the Z Rod is the oil that will give us the balance between a racing oil and a daily driven car and how this happens is simply because it carries the correct amount of zinc and phos and still has the detergents.
Old May 19, 2011, 07:41 AM
  #40
wally7714's Avatar
I`m sold. Placing my order now
Old May 19, 2011, 02:19 PM
  #41
Boltz.'s Avatar
I don't understand why you wouldn't share the ZDDP values....
Manufacturers usually give those out and there is also an abundance of information from testing labs like blackstone that people post over at bobistheoilguy.com.
It shouldn't be a secret and frankly if the values are higher than the competition, why wouldn't you want to share them?
Old May 19, 2011, 04:15 PM
  #42
boostedwrx's Avatar
^ someone needs to buy some, run it, and send it in the Blackstone. I always trust 3rd party results over manufacturer (no offense Andy lol). Im sure it's only matter of time before its up on BITOG.com
Old May 19, 2011, 05:51 PM
  #43
Fast_Freddie's Avatar
I have a case of 20-50 on the way...
Old May 23, 2011, 06:21 AM
  #44
apagan01's Avatar
i will buddy share the info , very soon.
Old May 23, 2011, 06:24 AM
  #45
apagan01's Avatar
I dont blame you, i also like to find out for myself what they are saying is truth or not, i can tell you though that in these matters AMSOIL has to be very carefull because there are companies out there just waiting for a slip in false advertisement to slap a law suite,,, so i bet you the number are very accurate.
look at what has hapend to royal purple, mobil and some other comanies that were claiming 100% synthetic oils, they got bit in the rear.
Quick Reply: Amsoil introduces new Z-Rod high ZDDP oil line
