....to bead or not to bead? that is the question i have
Old May 9, 2011 | 01:42 PM
5 ltr. beater's Avatar
ok...so:
i just purchased the fujita hardpipe kit for my evo ix and me and my buddy noticed that the end part of the pipes that connect to the intercooler are not beaded. (see pic below)
but the rest of the pipes are ok. (the ones that connect to the TB and go down towards the intercooler.
its just that the ones that connect to the intercooler arent beaded.
i called customer service and they said that its fine and its not a problem.
i tried looking online for any bad product reviews but found none.
so im confused, should i bead it or let it be?
has anyone heard of any problems with the fujita intake kit?
will i be ok if i dont?
is there not much room for the hose to pop off and is that why they didnt bother beading it there?
i spike 31lbs of boost on the stock turbo so im thinking I shud bead it but if fujita didnt do it, am i overreacting?
Old May 9, 2011 | 01:56 PM
AlwaysinBoost's Avatar
LICP are notorious for blowing off and when they do its usually a PITA to get them back on since you have to jack the car up and/or remove the undertray.
I've run a couple different LICP's, most recently was a SS 2.5" LICP that was beaded but didn't have any brackets like OEM to mount to the frame, and I couldn't keep it on at the track even with T-bolt clamps. Switched back to the crappy OEM unit with both brackets attached over a year ago and haven't had an issue since.
So in summary I wouldn't put that on unless it was beaded, and even still I wouldn't run it unless it had both brackets like OEM. YMMV.
Old May 9, 2011 | 02:01 PM
sho669's Avatar
IC pipes should have bead rolled ends, no question in my mind.
I've run the Nisei pipe (cut the bracket off) and the ETS (no bracket) at 30+psi for 70+ drag passes and 2 years of DD time, never had a pipe come off. I've always run t-bolt clamps and silicone couplers though.
Old May 9, 2011 | 02:08 PM
Kracka's Avatar
I won't buy an IC pipe unless it had beads and mounting brackets.
Old May 9, 2011 | 04:11 PM
ok well it looks like im gonna have them beaded then.
however the aftermarket LICP doesnt have a bracket, will i still be ok if i just have it beaded and sealed up pretty good?
Old May 9, 2011 | 04:16 PM
sho669's Avatar
See my post above, it's a personal preferance thing really. Some guys swear by them and most run without since a lot of the aftermarket ones do not use the bracket.
