BR piston with HTA 35R comp ratio ??
Old May 14, 2011 | 05:37 AM
picco97's Avatar
Hi
buschur 2.0L pistons are 10.5:1 comp ratio
i think this ratio pretty high with hi-boost set up
If I set up :
GSC powerdivision CNC PORT HEAD (bronze guides 1mm valves inconel ex valves 11000rpm springs tatinium retainers etc..)
BUSCHUR 10.5:1 piston
BR aluminuim rods
eagle 4340 2.0L crank with bearing set
race balance eleminator kit
HKS 280 IN/EX cams
AEM EMS with twinpire and pancil coils kit
BR buschur HTA GT35R kit with BR tubular header
If i use 10.5:1 BR piston what can i use maximum boost on 91 octane pump gas and 108 octane race gas
also eatimate each HP
I haven't decide piston comp ratio yet but what can i have benefits comp ratio choosing if i use 10.5:1 and 8.5:1 or 9.5:1
I will make 91 pump gas and 108 race gas maps
My goal is 650-700 WHP using 91 pump gas at 10,000RPM. that's why I will not use stroke kit
the most curious things what will be different each CR ratio on this set up boost
what is best choice on my goal
can it possible to make 650HP 91 pump gas on this setup ?
I was send BR to ask this things but they answered me simply (depend on)
thanks
Old May 14, 2011 | 05:40 AM
picco97's Avatar
1000cc RC injectors and may be add 70mm big bore with magnus intake manifold or some other simailr brand intake manifold
Old May 14, 2011 | 10:32 AM
aka.ralliart15's Avatar
Your expectations are way too high and at 10,000 the turbo is done.
Old May 14, 2011 | 12:20 PM
[I.R.A.]_FBi's Avatar
yeah. depends on if he's after a power goal a time goal or an rpm goal, readjust goals/turbo/rpm to suit
Old May 14, 2011 | 01:29 PM
Boostfiend's Avatar
10.5:1 seems to be a little high of a compression ratio for California **** water (gas). Any reason why you chose that comp ratio?
Old May 14, 2011 | 11:12 PM
evosam726's Avatar
i dont see yourself getting anywhere near that hp goal on just 91...
Old May 15, 2011 | 01:50 AM
picco97's Avatar
I asked buschur racing about different ratio they have one CR 10.5:1. They said " we only have one CR 10.5:1 and using this CR all of our mod car"
I didn't decide CR ratio yet. I'm asking here for find out better choice of CR ratio using CA 91 pump gas
what can I expect HP this set up ? anyone have idea?
Shaun@AWDMotorsports
Evo 'For Sale' Engine Internals and Drivetrain
206
Feb 6, 2016 05:36 PM
EVOlunchbox
For Sale - Cars For Sale
Feb 2, 2016 08:20 AM
Boosted Tuning
Nov 6, 2012 03:49 PM
David Buschur
262
Sep 25, 2008 06:41 AM
DynoFlash
48
May 16, 2008 09:55 AM
