How do you know your EVO has front LSD, AYC/ACD?
Old Dec 22, 2003 | 08:35 AM
x7eVoLuTiOn7x's Avatar
Old Dec 22, 2003 | 08:50 AM
YellwTyper's Avatar
You can probably tell by looking for hydrolic hoses coming out of your rear diff. Also if you had ACD/AYC you should have a button that change into different settings...i.e. tarmac, gravel, and snow.
Old Dec 23, 2003 | 07:59 AM
I got the ACD button TARMAC, GRAVEL & SNOW. I thought the US version had them also? Does that mean I also got the AYC if I have the ACD? whats ACD mean?
Old Dec 23, 2003 | 03:52 PM
memo3's Avatar
ACD helps you make u-turns faster...
ACD stands for Active Center Differential..
basicly it gives u a better traction and AYC is a system that gives better torque distribution betweent the rear wheels...
Old Dec 23, 2003 | 07:33 PM
JaMa's Avatar
None of this
IIRC the US version of the Evo does not have any of this. Just plain ole active torsional coupling center diff.
You could look at this as good or bad. Although, IMO less electronic crap is a good thing.
J
Old Dec 23, 2003 | 07:37 PM
memo3's Avatar
I like the US Center Diff... i think it works pretty good...
Old Dec 23, 2003 | 07:52 PM
Crufty Dusty's Avatar
Nope, it is possible to have ACD without AYC.
Old Dec 23, 2003 | 07:55 PM
Re: None of this
J
I would just like to understand for the sake of the argument why "less electronic crap" is [necessarily] "a good thing".
Old Dec 23, 2003 | 07:59 PM
Cabo's Avatar
Less electronic crap = less stuff that can fail.
You already have a mechanical system -- to add a whole other variable in the form of an electronic system that must work in conjunction with a mechanical system increases your chances of failure.
When you're engineering something complex, simple is almost always easier (but not necessarily better when it is in good working order).
Cabo
Old Dec 25, 2003 | 01:36 PM
JaMa's Avatar
Re: Re: None of this
I also said IMO "In My Opinion" less electronic crap is a good thing. The EVO is general is all about being in contact with the road. You feel every bump, every slide, every drift, everything.
Go drive a go-kart sometime. It has an engine, mechanical steering, manual brakes, no suspension to speak of. And in a gokart, you are literally in 100% control.
Electronics are for people who cant drive. If you dont agree with this, you should have bought an STi or something more complicated IMO. I dont like having a computer drive for me.
J
Old Dec 25, 2003 | 07:21 PM
GDB's Avatar
GDB
Oh no, another 'armchair' debate
ALL IMHO:
In terms of RELIABILITY, I wholeheartedly agree that less electronics = less things to go wrong.
However, in terms of PERFORMANCE or DRIVING FEEL, how many of us are actually qualified to give an opinion? Has anyone ever driven with and without ACD/AYC with the same Evo?
Hence I call this 'armchair' debate.
The closest thing I can contribute is this: I drove a no-electronics STi prior to the current ACD/AYC Evo. Evo wins hands-down in terms of handling at the limits. But how much of it is due to ACD/AYC, I do not know because I can't turn off the system (of course).
But then again I do understand the "pride" or "achievement" of driving a car fast/well when it's not supposed to. Kind of like that feeling you get after you hit a sweet 3-iron with a blade, while you could have easily done the same distance with an oversized 7-wood.
Personally I'm all for electronics. If all of us are stuck with "screw electronics" mentality, we won't have ABS now. And without ABS God knows how many more accidents occur on the road today.
Old Dec 25, 2003 | 08:53 PM
raywong's Avatar
My car has ACD/AYC, it suppose to help entering and exiting conners. when entering, the engine braking torque is distributed to the inside wheel to reduce understeer. when exiting, the torque is transfer to the outside rear wheel to induce tail movement. I have not tried to enter conner fast enough to feel the difference but I could control power slide and hold it by the thorttle easily exiting conners. It sure helps novice drivers like me.
Old Dec 26, 2003 | 04:02 AM
gunzo's Avatar
ACD gives torque distribution between the front and the rear wheels dependin on driving conditions (ie acceleration, deleceration, cornering)
AYC controls the split between the rear left/right wheels to aid in turning the car.. it works like a mechnical LSD except it works in conjunction with the brakes too to slow the inside wheels to create a yawing moment into the turn .. hence 'yaw control' ..
Old Dec 26, 2003 | 04:07 AM
gunzo's Avatar
Take a hard corner at speed in tarmac mode ..
then take the same corner at the same speed in gravel mode .. then you'll feel the difference
I don't think it's a matter of novice .. it's a matter of habit
Experienced drivers are so used to mechnicals and skills that electronics hinder them .. but imagine these experienced drviers 'experienced' on the ACD/AYC .. they'll beat the crap out of us novices
Old Dec 26, 2003 | 05:18 AM
keviin's Avatar
read your owners book...
