Balance Shaft Elim Guru's
Old May 18, 2011 | 07:21 PM
TTKID's Avatar
I'm in the process of putting my block all back together and figured I'd do a balance shaft elim while I was there. I've been following this site http://www.vfaq.com/mods/balance-shafts.html. I followed all the steps on the pump, got it all apart installed the plug and stubby shaft. My main question is on the bearings. My kit came with 3 bearings. The one right at the pump is pretty straight forward. I lined the holes up just like one in this pic. Does the one behind the one at the pump have to pressed in with the holes aligned as well? Any input it appreciated. Thx
Old May 18, 2011 | 07:37 PM
Matthew333's Avatar
You have to "block off" all of the oil passages that do not have a need- With the stubby shaft, that's all of them-
Old May 18, 2011 | 09:54 PM
batty200's Avatar
the holes need to be NOT LINED UP. the purpose is to block off the oil feed since there is no shaft to oil anymore.
Old May 20, 2011 | 06:41 AM
TTKID's Avatar
Thanks for your helps guys. Got it all together last night.
