evo crank has play
evo crank has play
Whats up everybody i have a evo 9 i can not figure out the problem maybe some one experienced the same when i push on the clutch it moves the crank and breaks the crank sensor i know the crank has play but the motor was just rebuilt with oem everything i can not figure out the problem only drove 250 miles on the new motor when this happened let me know if anyone has any ideas... Thanks
sounds like something has gone wrong.
call your engine builder and explain to them the situation.
if it's as bad as you're saying, the engine will need to be removed.
stock crank end walk measurement is like 0.1mm. not enough to smash Crank angle sensors.
Yeah if the thrust bearing isn't in there or has "worn" out due to not being installed properly then it would move enough to break the sensor. Well it's the blade that breaks the sensor not the crank itself :P Good luck.
Aaron
Aaron
I will put $$$ on no thrust bearings on one side or both sides.
