Carbonetic Multi plate rebuild
Old Jun 22, 2011 | 11:13 AM
MikeB@FFTEC's Avatar
I'll be posting that up soon. I actually did launch the car once or twice. There is a warm up procedure for the clutch to prevent damage to the disks.
Old Jun 22, 2011 | 05:20 PM
Just for kicks I did a weight comparison between the ACT HDSS clutch and flywheel, with a carbonetic twin plate. The weight should be about the same for a triple. The only additional weight would be the additional clutch disc and floater plate.
Clutch cover
Pressure plate
Clutch disc 1
Center hub
Floater plate
Clutch disc 2
Flywheel, and clutch basket
Act clutch
Pressure plate
Clutch Disc
Flywheel
So for the ACT that makes a total weight of 29.8 pounds.
The Carbonetic twin plate all together weighs
File Type: jpg
Old Jun 22, 2011 | 10:06 PM
project_skyline's Avatar
So how many miles were on it before you had to replace a few parts?
What did those parts cost you?
Old Jun 24, 2011 | 12:13 AM
daisaw1219's Avatar
i previously had one that lasted 50k miles of constant abuse, and two people learning how to drive stick shift. I wanted to rebuild it but one of then vendors here quoted me about 1500 to rebuild, I paid 1650 at the time, so I decided to try a different brand. MikeB if you have a hook up let me know, its sitting in my basement and could use a rebuild.
Old Jun 24, 2011 | 03:05 AM
94AWDcoupe's Avatar
this is likely the worst statement ATS has made concerning their clutch. these clutches hold fine when cold. yes they hold more when hot. problem is if you slip them on purpose to get heat in them it potentially puts far too much heat in the metal plates. once the metal plates warp the clutch dies pretty much instantly. I saw here on evom years ago many killed these on their first visit to track. two seconds of slip warm up is needed. four seconds can kill the clutch. bad idea to slip them if you ask me. they obviously hold up to tremendous mileage on the street. shame to kill them at the track.
iIF ANYONE HAS WELL USED CLUTCH I am in need of a parts clutch.
Old Jun 24, 2011 | 12:45 PM
According to the instructions it isn't.
http://www.carbonetic.net/tech/pdfs/...win.Triple.pdf
Old Jun 24, 2011 | 01:04 PM
Fp3052's Avatar
I have a triple that needs a rebuild, how would you know if the floater plates need to be replaced?
Old Jun 24, 2011 | 04:56 PM
Is the clutch still in the car or have you removed it already?
Old Jul 5, 2011 | 11:46 AM
Fp3052's Avatar
Its off the car
Old Jul 6, 2011 | 09:27 AM
Pmed you.
Old Jan 9, 2012 | 02:13 AM
nspyr's Avatar
Hi can you give me info on where you get your parts for the Carbonetics triple plate clutch rebuild...also what is the cost for these parts... Thanks
Old Feb 2, 2012 | 01:53 PM
bigblackevilevo's Avatar
Thanks for the post man that and MAPerformance suggesting this clutch really helps me decide on going with the Carbonetics triple carbon clutch when my exedy twin HD dies.
Old Feb 3, 2012 | 09:34 AM
No problem. It really is a great clutch and I'm glad the write up helps.
Old Feb 4, 2012 | 02:27 PM
jessmanEVO's Avatar
^^^ +1
Mike recommended me this clutch for my expected power level. I've been driving around on the streets with it and it feels great!
Old Feb 6, 2012 | 12:07 PM
Originally Posted by jessmanEVO
^^^ +1
It's time you joined the 600 club!
