what is the best low expansion alloy Piston?
Old Jun 6, 2011 | 01:40 PM
supersal's Avatar
Originally Posted by acssa
all the 4032 ones I saw failed way before the 2618.... but thats just here in sunny SA.
I think a lot depends on the tuning and set-up of the cars - most of my experiance is with in-line fours and not Subaru boxer engines so I cant speak for failures on them but in the Turbo Opels I've had we have seen factory Mahle's last just as long as 2618 pistons m aking similar power... There are also stock Evo pistons holding plenty of power on good knock free tunes...
But to each their own - like I said I got nothing against 2618's have run them before without issues on a couple of my motors...
Old Jun 6, 2011 | 02:00 PM
RSMike's Avatar
I'm sorry, i didn't realise JE and Wiseco do 4032 alloy pistons. I googled it but didn't come up with anything.
I will look into JE models, But they do not offer a 86mm bore is the SRP Pro series. I'll ask for a "normal" 4032 piston.
Supertech do not make a 86mm piston for 100mm stroke.
Ok here are some numbers
EVO130385I19 - Mahle 86mm bore, 100mm stroke, 22mm pin, 9:1 comp ratio, 280 gram.
http://www.us.mahle.com/C1256F790053...20complete.pdf
K596M86 wiseco 310gram. 9:1 comp ratio
k627m86 wiseco 1400HD 305gram. 9:1 comp ratio
http://www.wiseco.com/Catalogs/ProTr...eteCatalog.pdf
Mahle pistons look very nice!
And very light!!
Old Jun 7, 2011 | 11:12 AM
laramie_05MR's Avatar
Originally Posted by 94AWDcoupe
Mahle hands down. Been sold on them for years. I have run just about everything out there. Hold a mahle in your hand next to any other other piston. mahle is a step above. The machining is incredible.
wiseco and JE both offer 4032 alloy on request. JE would be my second choice.
I use Mahle as well in all my builds. Import and domestic.
Old Jun 7, 2011 | 12:38 PM
RSMike's Avatar
JE have replied back stating that a 4032 vs 2618 only expands 15% less. Very Negligible.
Piston to bore clearance is recommended at 3thou, with people running them as low as 2.5thou with 500hp and very good tune.
My tuner runs his HKS pistons at 0.04mm clearance! 1.6thou!
And having it this tight, there is LESS wear on the skirt because less of a chance for them to rock in the bore.
Looks like Mahle it is, they have recommended clearances from 1.6thou to 2.4thou.
Old Jun 19, 2011 | 01:31 PM
RSMike's Avatar
I got very very comprehensive email replies back from Mahle.
I have decided to try them.
If you want more info i can post here and/or PM you.
Cheers, Mike
Old Jul 25, 2011 | 01:48 PM
RSMike's Avatar
My 86mm Mahle pistons have landed.
They are a very nice piece of kit!
277grams each, 122grams per pin.
411grams total (piston, pin, retainers and rings)
Does anyone know if the Mahle pistons are made to suit 1mm oversize valves as standard?
Also the piston to bore clearance is 0.002" to 0.0024" straight out of the box (assuming 86.000mm bore). I measured them myself.
Old Jul 25, 2011 | 08:10 PM
wreckleford's Avatar
Pics?
Old Jul 25, 2011 | 08:36 PM
RSMike's Avatar
i can get some for you on the weekend. Will update the thread then.
Old Jul 25, 2011 | 09:37 PM
sparky's Avatar
I can't wait. Don't forget to post up those pics, GL
Old Jul 25, 2011 | 10:19 PM
RSMike's Avatar
Are there any pics you want specifically?
I.e. how the 2nd ring land lower support (i.e. crank side of 2nd ring) is actually a smaller diameter than the top ring land? (why the hell do they do that? lol)
Old Jul 25, 2011 | 10:35 PM
ZMX's Avatar
ZMX
They make low expansion pistons. They're called hypereutectic. They break more easily.
Why do you want that?
Old Jul 25, 2011 | 10:52 PM
RSMike's Avatar
They (Mahle) make both kinds of alloy pistons (2618 and 4032)
Yes they break more "easily" than the softer 2618 alloy.
Does that worry me? No.
I like the tigher piston to wall clearances. 3thou, yes please
Old Jul 25, 2011 | 11:00 PM
ZMX's Avatar
ZMX
The piston to wall clearances on a 2618 piston won't be small once it's heated up.
btw, 4032 alloy pistons aren't hypereutectic. They won't best fit your standards of cool engine PtW clearance (I still don't know why you care).
Old Jul 26, 2011 | 10:28 AM
SeanC's Avatar
Originally Posted by 3grst01
You have over 1000 posts yet still haven't found the search feature . . . Here let me provide this link I found from google for you. http://www.jepistons.com/Catalogs/SR...ishi/4g63.aspx
4032 type piston is what you are asking about btw. 2618 is high expanding
The SRP Professional series pistons above from JE were specifically made for street cars in the 500hp range and under. If you're looking for a high quality, forged piston for your street car...these are the ones. These parts were a clean sheet design, designed using finite element analysis with the specific load conditions experienced in our engines. AMS has them listed here:
http://www.amsperformance.com/cart/J...r-Pistons.html
I'd say the SRP Professionals are the perfect street pistons but for that and everything else JE now has new asymmetrical pistons. They require less clearance, are very light, use 2618 alloy and are designed for heavy side loading associated with turbo engines. These parts have a contoured undercrown (thicker in center) that better handles the heat from combustion, an offset wrist pin (quieter and balances the piston), brushed crown (reduces likelihood of preignition) and uses a shorter stiffer wrist pin. Here's the latest info:
http://www.jepistons.com/Articles/10...d-Pistons.aspx
Both Buschur and AMS are using the asymmetrical parts...
05EV08
Northeast Region
Jun 28, 2016 10:10 PM
shomesomesho
Apr 12, 2014 04:06 PM
Jackson Machine
Nov 21, 2010 08:22 PM
Vivid Racing
Dec 11, 2008 01:45 PM
