best 272 cam on stock valve spring
Old Jun 8, 2011 | 12:47 AM
  #31
riceball777's Avatar
i have had HKS 272's for 80,000 miles. rev limit is set to 8,000 rpm. the car has always idel and ran great
Old Jun 8, 2011 | 08:56 AM
  #32
dat*niz's Avatar
+1 on hks 272's,i got 93,200 miles on my car and idles perfect
Old Jul 21, 2011 | 11:42 PM
  #33
BlackOpsEvo's Avatar
Registered User
I'm about to put cos m2 cams on my stock evo ix, hope it works out
Old Aug 24, 2011 | 11:05 PM
  #34
G20's Avatar
G20
Statistically, HKS 272s without upgrade valves and springs you should be fine revving below 8k.
It's not like the stock Mitsubishi valves and springs are made from glass. They're actually quite good and quality. I don't make statement out of my azz, I'm experience it. My two evos have been running the HKS 272s for its life with lot driving. I know bunch of oldtimer evos since 2003 been running the cams (they're the first cams available for the evo in the states) with stock valves springs no problem. For the person called it CIRCUMSTANTIAL, there's a thing called STATISTIC.
Old Aug 24, 2011 | 11:34 PM
  #35
nightwalker's Avatar
Helix hollow 272 cams, 140,000 miles! Still running. Stock valve train.
Been thinking about S2's or Kelfords actually....
Old Aug 25, 2011 | 11:36 AM
  #36
thepoint4life23's Avatar
https://secure.buschurracing.com/cat...fc947a7e2df354 are they good to run?
Old Apr 18, 2012 | 12:21 AM
  #37
gavi101's Avatar
Hi all
I just want to know if HKS 272 in and ex cams will be overkill for a stock evo 6?
And will the stock evo 6 valves and springs handle the HKS 272 cams ?
Cheers
Gav
Old Apr 18, 2012 | 12:42 AM
  #38
nunother's Avatar
How much Hp can be added with basic addons, intake/exhaust
Old Apr 18, 2012 | 10:32 AM
  #39
dastallion951's Avatar
@G20 yup I ran the 272 hks cams before i liked em idle and low rpm driveability was easier, compared to the s2s. stop and go traffic with these s2 cams, its all in throttle modulation, light throttle not completely letting off kinda helps with the car buckin n jerking, of course theres not a traffic situation im in where you cant hear cuss words out my window. Because people here in socal drive like idiots especially on freeway traffic haha. But comparing a pull with s2 cams it feels like between 3-5k, the cams being not as aggressive felt like slightly increase in pull low end to midrange over s2s, but once it hits with the s2s its a seat rest pusher, i feel snug in my backrest haha.
@nightwalker personally you will see an improvement in s2s over the helix cams, iirc i remember reading a cam test I believe the helix cams were on there, and no offense i believe were one of the lower performers. The s2s will help a lot, but personally with 140,000 on your engine, i would do springs/retainers but i would also look into arp head studs unless you have them installed.
@Gavi, yes your springs/retainers should be fine on the hks 272 cams, the valve lift is less then a mm on both your intake and exhaust valves, you wont be worried, but if your using stock valve springs/ retainers id make the rev limit prolly 7500 -8k dependin on if your making good power at those rpms.
@nunother depends on your definition of exhaust, catback, testpipe, downpipe, with all those and an intake, depending on your dyno could be 300hp 300 tq maybe a little more, maybe less. Depends too many factors to rule in that kind of guessing game.
Old Apr 18, 2012 | 11:09 AM
  #40
safat_evo's Avatar
for stock spring u should go for hks
Old Apr 18, 2012 | 12:21 PM
  #41
cmspaz's Avatar
+1 for HKS on stock springs.
Anything else and you're increasing lift over the design parameters for said springs and retainers. If that's a risk you want to take, that's on you. I passed up a set of (coveted as far as I'm concerned) Revolver 264s for my HKS272s because I couldn't afford to do springs and retainers at the time.
In the end, it falls under the Cheap/Fast/Reliable choice we've all heard a million times.
Justin23
Jan 3, 2017 08:32 AM
Black_EVO_MR
Nov 9, 2016 05:10 PM
740 Turbo Brick
Nov 8, 2015 12:24 PM
moevo9
42
Oct 26, 2012 01:58 PM
ilikeppie
Sep 17, 2012 03:39 PM
