5 speed sheptrans won't go from 3rd to 2nd
Old Jun 6, 2011 | 07:25 PM
crimes's Avatar
I'll keep this short, basically what the title says.
Running hks l.a clutch
Box has done less than 1000 miles
Car was warm
Light chattering noise heard from gearbox on idle
Has only been launched twice
1st to 2nd shift has felt notchy before it was running for the first time
Could smell clutch after a normal drive, a very light smell
Gearstick would go down from 3rd to 2nd but could not feel the gears engage
Has only recently not engage from 1st to 2nd when changing at 6500rpm
Now here's the part that baffled me, this morning I drove it to work and 3rd to 2nd shift was normal again... Help?
Old Jun 6, 2011 | 07:43 PM
WHTEVO's Avatar
Sounds like a clutch adjustment issue to me. Check to make sure everything is bled out and adjusted properly. Good luck.
Aaron
Old Jun 6, 2011 | 07:59 PM
mrg72433's Avatar
Also check the cables, they could have gotten bent or pinched somewhere
Old Jun 7, 2011 | 08:03 AM
barneyb's Avatar
During a normal drive you should never smell clutch. Something is wrong with the clutch adjustment or the clutch itself.
Old Jun 7, 2011 | 08:05 AM
teribble's Avatar
x2
Old Jun 7, 2011 | 11:25 AM
CO_VR4's Avatar
Originally Posted by teribble
x2
I hope you make it clear that you have no idea what the problem is, and when you find it, you post it immediately.
When you start a thread like this with a title that suggests that a particular vendor's build is involved, people naturally associate one with the other. I don't own Shep transmissions, but I can see why this kind of title would be frustrating to a vendor, particularly when you have not called and asked them about the issue that you are having...
Good luck with solving your shifting issue.
The suggestion about shifter cables (and brackets) is also a good one. If you have aftermarket shifter bushings installed, they sometimes can expand with heat and lock up the shift mechanism, acting like transmission problems when they're not...
Doctro X
Sep 8, 2019 12:03 AM
marcusE
Mar 19, 2013 10:01 AM
AFD
Dec 8, 2011 12:37 PM
chase123
Feb 9, 2009 09:00 AM
desperado-c
Mitsubishi TC-SST Discussion
Aug 8, 2008 05:09 PM
