balance shaft question
Old Jun 26, 2011 | 10:20 AM
n2oiroc's Avatar
im piecing together my new engine, but the stock one is still in the car so i have nothing to reference. im doing the ams style balance shaft but im not sure how it goes together. i imagine the oil pump is driven by the gear with the stub sticking out, and the race shaft bolts right to the other gear like this but what goes over the end? a sprocket? short bolt and plug? a search wasnt very helpful and i cant find decent pics.
Old Jun 26, 2011 | 10:24 AM
wizzo 8's Avatar
Timing belt sprocket goes on the bottom one which is the oil pump.
Old Jun 26, 2011 | 10:26 AM
n2oiroc's Avatar
what about the other one right above it, where the shaft goes in?
Old Jun 26, 2011 | 10:29 AM
wizzo 8's Avatar
Just looked at mine and there is a metal plate that goes there.
Old Jun 26, 2011 | 10:35 AM
n2oiroc's Avatar
makes sense. i just looked and its threaded so i just bolt the shaft to the gear and a plug threads into the hole and covers it all up. thanks!
loneracer05's Avatar
Pm oneofakindracer he should have some pretty good advice.he just did this kit on his car.
Old Jun 26, 2011 | 10:45 AM
okevolutionVIII's Avatar
I believe there's a brass castle plug that cover the end. I just finished doing this mod myself.
Old Jun 26, 2011 | 10:48 AM
wizzo 8's Avatar
Correct its a round plate with castle top edges if that make sense
Old Jun 26, 2011 | 11:33 AM
n2oiroc's Avatar
does the plug require a special tool to tighten it?
Old Jul 2, 2011 | 06:17 PM
n2oiroc's Avatar
im about ready to install it, but i checked the bearing that it rides in and its ground by the overlap of the backing on the bearing surface side and the oil feed hole in the bearing does not line up with a oil feed in the block. i imagine the machine shop thought i was running a stubby shaft and installed all block off bearings and i need to replace it with a new bearing and line up the oil feed, right?
in the top pic, the overlap is around the 9 o'clock position and in the 3 o'clock position in the bottom pic.
Old Jul 2, 2011 | 06:24 PM
batty200's Avatar
The balance shaft provides the oil on that shaft. It doesnt matter where the holes are on there.
Old Jul 2, 2011 | 06:30 PM
n2oiroc's Avatar
what about the marks on the bearing? why the ground strip at the overlap?
Old Jul 6, 2011 | 08:36 AM
batty200's Avatar
I am not one who would use a balance shaft of any sort but if the bearing is smooth that could be a manufacturing artifact and no issue. If it is rough I would replace it.
