Weird clutch issue
Old Jun 29, 2011 | 01:08 PM
grim~'s Avatar
Weird clutch issue
Ok i replaced my clutch,flywheel and transmission about two months ago and ever since then when i go to a stop and push in my clutch pedal and keep it pressed in and put it back into first it feels like the clutch is already grabbing the flywheel as soon as i barley let off the pedal. But if i goto a stop and put it in neutral and let out the clutch pedal then push the pedal back in and go from first it doesnt suddenly move or grab and drives normally. Could this be a pedal adjustment issue? i bled the clutch sunday and there was some air in the line,but thats all good now.
Old Jun 30, 2011 | 07:01 AM
grim~'s Avatar
Anyone?
Old Jun 30, 2011 | 08:21 AM
F0RSAKEN's Avatar
Next time you drive the car, before pushing in the clutch to engage 1st (or whatever gear you get the issue in) try pulling the pedal up first. If it comes up more than about a half inch, pump it once or twice before putting it in gear. If you don't get any of the problems, it could be a couple things: pedal adjustment, still air in the system, leak in the clutch slave/master cylinder.
