Cooling system being pressurized??
Old Jul 7, 2011 | 06:03 PM
mithrandir7533's Avatar
Check your oil and see if it has coolant in it. My car did the same thing you are describing and eventually a piston disintegrated from the increased pressure the coolant was creating from foaming my oil.
I would not drive your car unless you absolutely have to.
Old Jul 7, 2011 | 08:37 PM
car_nut15's Avatar
The car is parked for now. Need to order up a waterpump and headgasket. As for the o-ringed head, where can I find replacement o-rings? Is there a standard size or am I best off measuring them when I take the head off?
Old Jul 7, 2011 | 09:18 PM
2slow4now's Avatar
Your O-rings in the head are metal and should stay in the head. They aren't much more than a thin wire but they do make different ones. You probably need to take it to a machine shop.
xRoguex
Dec 6, 2021 07:58 AM
NJ_EveOhVIII
Sep 6, 2013 06:34 PM
Acree
466
Jan 16, 2013 01:37 PM
dragon831
May 25, 2012 01:26 PM
Spoolin4g63
Jan 11, 2012 10:53 AM
