My Compression Test
Old Jul 10, 2011 | 03:43 PM
Colbyy's Avatar
My Compression Test
Just did a compression test engine was cold (well its like 80 degrees out today but I didnt run it first i mean) did it with the gas to the floor and got 160 175 170 175. Would just like to know if thats good with the 160 in there. Ive been suffering from overflowing antifreeze out the overflow and everyone says head gasket so just curious on the numbers.
Thanks
Old Jul 10, 2011 | 03:56 PM
NewEvolutionIX's Avatar
Thats Awesome! 145 is Spec
Old Jul 10, 2011 | 04:24 PM
Colbyy's Avatar
This was without the engine warmed up tho. So you dont think the head gaskets bad with those numbers?
Colbyy's Avatar
Forgot to mention its an 05 with 52k on it
Old Jul 10, 2011 | 05:58 PM
BluEVOIX's Avatar
Might want to metion if its stock block and head?
Old Jul 10, 2011 | 06:06 PM
wannabeanevo's Avatar
Do a leakdown test and that will tell you where your problem is.
Old Jul 10, 2011 | 06:08 PM
Colbyy's Avatar
Yeah its stock. was told that 160 might be a broken piston ring? and could be causing all my problems
Old Jul 10, 2011 | 06:58 PM
AlainD's Avatar
could be your HG
Old Jul 10, 2011 | 07:02 PM
4RETECH's Avatar
This might sound weird, but bring it to any place that has a gas analyzer. They can see the hydrocarbons in the cooling system if they put the probe at the coolant cap opening.
Also they make testers for head gaskets at the auto parts stores now.
Good luck
Old Jul 10, 2011 | 07:18 PM
riceball777's Avatar
numbers look goo to me
as long as all the cylinders are clore to the same your good
Old Jul 11, 2011 | 03:26 AM
Colbyy's Avatar
Yeah i plan to do a leak down tomorrow and a block test sometime to see
Old Jul 11, 2011 | 06:59 AM
Your supposed to test cold for compression but if your having problems then do a leak down test. But i don't see how you have a problem bc if you have a blown hg or have open valves it's going to read lower than 145 not higher. And the only way I can see it reading higher is if you had coolant in the cylinder but then you would be having white smoke out the exhaust, but I don't think every cylinder would be like that
Old Jul 11, 2011 | 11:26 AM
Colbyy's Avatar
It was cold. but no i have no white smoke just the coolant pushing into the overflow till it overflows did thermostat and cap. Doing leak down tomorrow.
Old Jul 11, 2011 | 02:36 PM
Liqquid's Avatar
doing this on boost I take it?
Old Jul 11, 2011 | 04:34 PM
apagan01's Avatar
leackdown test is a must when you have inconsistant numbers across the board, spcially when you are saying overflow tank is filling up
