Coolant Overflow - Retorquing head stud
Old Jul 12, 2011 | 12:52 PM
Dream Came True's Avatar
Hi. It's been a while but I want some opinion.
My 03 Evo 8 with 62000miles on E85 with 380whp/362trq is mainly used for autox.
I got my timing belt and water pump changed out and this is where my problem seemed to be started. First the harmonic balancer was installed 180 degree off so the motor had a really bad vibration above 4000rpm. It was taken care of.
Also, at the same time, the mechanic didn't burp the cooling system so after my autox run, the coolant was over flowing. I burped the system but the overflowing issue did not go away. I thought that was my poor burping skill. I bled like 3 times 25mins each.
I thought the problem was fixed and went to a track day last weekend. I had a coolant overflow issue again. Once the reservor tank was completely empty. I bled the system before each session. Twice the stock water temp gauge started going up to 3/4 to "H" and I slowed down.
Now, I believe the head gasket is lifting. There is no significant amount of oil in coolant and there is no smoke from the exhaust and the motor oil seems really clean. I realized for a while before I got my 60K service done, it's not hitting the target boost. It's set at 26psi but hits like 24psi.
I'm wondering since the symptom of the blown HG is so small, if I can just get APR head stud and re-torque will work. If it doesn't work, it goes to reputable shop in the bay and get the HG replaced and head machined flat. I believe APR studs are re-usable.
Does anyone have any experience in just re-torquing the stud? Or am I just wasting time.
Old Jul 12, 2011 | 02:19 PM
sktng22's Avatar
Is the thermostat getting stucked closed? that could cause overheat
Old Jul 12, 2011 | 03:30 PM
I think thermostat is okay since I see more bubbles coming out after the fun kicks in. I'm going to check radiator cap.
Do you know if rad cap is standard for all car? I hate to grab one from Autozone but it's the quickest one for testing. Or should I grab Mitsu OEM?
Old Jul 12, 2011 | 04:36 PM
sktng22's Avatar
any radiator cap should be fine. some people on here think you should only run certain ones for some reason but if your getting one to check it at autozone its not gonna hurt it
Old Jul 12, 2011 | 08:11 PM
gkania's Avatar
Replace the headgasket. If you want to upgrade to a stronger one, now is the time. Cosworth or HKS.
FYI, your balance shaft was 180* out, not your harmonic balancer. Harmonic "balancer" or damper is your crank pulley.
Old Jul 12, 2011 | 09:01 PM
I will have to replace the head gasket if it is head gasket. I'm not gonna retorque anymore but I'm not getting the typical symptom of blow head gasket such as burnt coolat or oil in the coolant. Apparently, the bad radiator cap has similar symptom as I'm getting. Let's see.
Old Jul 12, 2011 | 10:03 PM
barneyb's Avatar
I'd guess that half the people on this board have radiator caps that don't hold pressure. They go bad rather quickly. A 16 lb. cap is all you need to replace the stocker.
I once had a thermostat break and just stay closed. I got about 1.5 miles before it got hot and it went from everything normal to Old Faithful very quickly.
Old Jul 13, 2011 | 09:06 AM
Hey barneyb, where did you get the information that we need 16lb cap? This is exactly what Autozone has so I might just go grab one. I don't wanna put a wrong cap and mis-diagnose the problem. I don't wanna change the HG if it's not the problem.
Old Jul 13, 2011 | 12:42 PM
opie's Avatar
I had the same problem mine was filling up the over flow tank because the head was lifting under boost and because we caught it early all I had to do is torque the arp headstuds from 70lbs to 105lbs and everything is fine. I would say new hg and put arp in and that would fix it
Old Jul 13, 2011 | 12:44 PM
barneyb's Avatar
Per the service manual.....
Radiator Cap Opening Pressure
Standard value 93 - 123 kPa (14 - 18 psi)
Old Jul 13, 2011 | 01:22 PM
LOL WUT's Avatar
Best bet would be to try the new rad cap first as it's much cheaper less time consuming. Hopefully that solves your issue, if not, it sounds like it may be time for a new HG.
Old Jul 13, 2011 | 02:28 PM
Thanks guys for the info! I'm gonna try out the rad cap today. Crossing my finger that's gonna solve the problem. If not, it's gonna be $$$. It'll be the first major issue with my car after I got the car in 03!
Old Jul 13, 2011 | 02:34 PM
I still have the stock gasket but just ordered the APR head stud. I was gonna retorque the head with the APR studs without swapping the head gasket. Did you already replaced the HG before you retorqued again?
Also, did you see any oil in coolant or coolant in oil?
Old Jul 13, 2011 | 04:09 PM
opie's Avatar
I did not replace mine. It was filling up my overflow tank by pressurizing the coolant system and no I did not have and coolant in my oil.I was told that what arp said to torque the bolts at is not enough on most evos.
Old Jul 13, 2011 | 05:56 PM
Good info, opie let me try that.
