Ceramic Coating Manley Piston's...?
Old Jul 14, 2011 | 12:16 AM
Phoenix*'s Avatar
Hi Gents,
I have all parts to rebuild my Evo 8 motor, however, I am in two minds on whether I should get the tops of my Manley Pistons Ceramic Coated...
Does anyone here have experience with coated pistons, and if so, please advise accordingly...?
This is the write-up of the local company offering these services:
Metallic Ceramic Coating (CBC2)
Product Description: CBC2 is a metallic ceramic coating designed for use in combustion chamber applications on non ferrous metals. CBC2 is a unique material that exceeds the capabilities of more traditional ceramics. CBC2 has all of the excellent thermal barrier characteristics without the tendency to crack and flake, common to other ceramics. In addition, CBC2 aids in heat movement within the combustion chamber causing convection. The heat movement barrier function increases combustion efficiency, through more efficient oxidation of fuel. In addition, the polished surface is not only highly reflective to heat, but provides minimal transfer of residual combustion chamber heat to the incoming fuel mass, thus reducing the chance of detonation. CBC2 has excellent carbon shedding characteristics, which also aids performance. CBC2 is unaffected by most chemicals. Survives thermal shock, can withstand temperatures in excess of 3000şF for short periods.
Applications: CBC2 is designed for single coat coverage and may be applied to non ferrous metal parts. Forms durable chrome like finish. Survives heat and forces of an internal combustion engine. Can be used on pistons for both petrol and diesel engines. May be used to protect aluminum parts. Not recommended for magnesium. See our piston burn video! Protect your expensive pistons….! Piston coating surviving 2000 degrees C.
Would appreciate some sound advice...
Phoenix*
Old Jul 14, 2011 | 03:48 AM
RSMike's Avatar
i would advice that coatings are a waste of time.
If you are serious, get them nickel coated.
Here is a pic of my pistons after 7000kms (approx 4500miles)
Here is the combustion chamber coatings
please bear in mind that this is in NZ. But i have NEVER heard of a "ceramic" coating that has lasted on a piston... Get someone to prove me to wrong.
this is nickel coating (sr22 HKS pistons) My tuner has done 4 years (drifting) on the same piston and the coating has not degraded at all (3 rebuilds later)
Old Jul 14, 2011 | 04:16 AM
loneracer05's Avatar
Oh jeez. +1. Go with nickle
Old Jul 14, 2011 | 09:47 AM
supersal's Avatar
The coating on my AMS manifold has pretty much burnt and peeled off over time...
I asked My fabricator today if its worth recoating and he said he hasnt seen an aftermarket ceramic coating that will hold up over time - so we decided the best thing to do is to titanium wrap it...
Old Jul 14, 2011 | 06:39 PM
jetsevo4's Avatar
Re: Coatings
If your going to do any type of engine coatings, then don't use anyone but Swaintech Coatings. Their white lightning coating is different from "ceramic coatings" and can really take a hell of a beating
Old Jul 14, 2011 | 06:48 PM
gsrboi80's Avatar
That stuff really doesn't hold up all that well either after some time.
Old Jul 14, 2011 | 11:27 PM
project_skyline's Avatar
I've never seen those ceramic coatings for pistons, exhaust chambers, or exhaust ports prove to last any decent amount of time or provide any real benefit.
Old Jul 15, 2011 | 12:37 AM
RSMike's Avatar
The coatings do provide benefits, they lower the overall heat transfer into the piston.
This can be seen with a car running oil squirters. If your tune is at the limit, there will more than likely be scorched oil on the bottom of the piston.
With coatings applied there is no scorching on the bottom of the pistons.
So it does work.
But it doesn't last sadly.
With Nickel coating, the thickness can be varies depending on process time. So you can have anywhere from 3microns up (0.0001" ish)
Old Jul 15, 2011 | 11:59 AM
Erik@MIL.SPEC's Avatar
It depends. The SwainTech White Lightening Coating is holding up well on my exhaust manifold. Some of it might come down to surface prep. I also painted my exhaust mani with hi-temp black paint.
Old Jul 15, 2011 | 12:05 PM
gsrboi80's Avatar
Yea def I'm sure prep has a lot to do with it but have def seen it peel and chip off exhaust components. Hell even on non turbo apps
Boostin Perform
Mar 6, 2020 09:01 AM
Boostin Perform
Evo 'For Sale' Services
18
Jun 28, 2019 01:21 PM
Boostin Perform
EvoX 'For Sale' Services
17
Apr 25, 2019 01:30 PM
garageGT
Aug 2, 2006 09:03 PM
