Tapping sound from hell ending BAD :(
Old Jul 17, 2011 | 09:46 PM
Darkn3s's Avatar
so after doing a pass at the track i notice a light tapping sound almost like something was hitting my fan.. so i slow down and the tapping slows down as well and when i gave it gas it sped up and got louder...
so i park it and pop the hood and find out its coming from head area almost like if it was a broken lifter or something in that area since it clearly sounded like it was coming from right under the valve cover..
so anyway we take it to a buddies house which is only a couple miles away from the track and take of the valve cover and inspect the best we could.. but nothing visible looked bad or out of place. so then i thought it was probably something minor and decided to drive it home... WRONG!..
well the tapping got really loud to the point it did it during idle and cars behind me could hear it.. so i try to coast it downhills to take load off it and it just CUTS off on me and turns off.. i luckly find a big wide shoulder area where i pulled over and pop the hood to see anything bad but nothin caught my attention. so i go try to turn it on again and NOTHING happens cranks ONE time and thats it..
stuck on the highway 4am and 2 hours later the tow truck guy finally shows up and take me home
now im on here trying to do research so if anyone has an idea of what it could be please chime in.. dont look forward in ripping her apart again
btw block is a fully built 2.0 and head is stock with BC 272 cams
Old Jul 17, 2011 | 10:01 PM
turbopineapple's Avatar
Sounds like rod knock
mikey
Old Jul 17, 2011 | 10:04 PM
02-Lancer-Es's Avatar
Sounds like it spun a bearing and now the crank is seized .
Old Jul 18, 2011 | 04:00 AM
psphinx81's Avatar
yup spun a bearing
Old Jul 18, 2011 | 06:22 AM
MRfabolous's Avatar
yup sounds like you spun a bearing how is your oil pressure that will reflect it also. the car will barely try to idle and the oil pressure will fluctuate a lot. if you have the car at idle and bring the rpms up slowly and the start getting louder at like 3k or so. you are going to need a new crank and all. hopefully you didnt mess up the rods more by driving it around.
Old Jul 18, 2011 | 07:28 AM
Darkn3s's Avatar
ahh man lets hope not
Old Jul 18, 2011 | 07:31 AM
ct9asilver's Avatar
Did you by any chance reuse or flush out and reuse your oil cooler?
Old Jul 18, 2011 | 08:01 AM
gsrboi80's Avatar
Sounds like Rod Knock for sure man. Good Luck on the rebuild
Old Jul 18, 2011 | 10:12 AM
Darkn3s's Avatar
i deleted my oil cooler because of a spun bearing with my stock motor
yea im afraid so.. anyway to verify that without taking it all apart??
Old Jul 18, 2011 | 10:22 AM
BenJ's Avatar
Take the oil pan off and you can inspect the bearing.
Old Jul 18, 2011 | 11:30 AM
psphinx81's Avatar
or take off your oil filter and cut it open, i bet theres a ton of metal in it..
Old Jul 18, 2011 | 01:36 PM
Darkn3s's Avatar
yea thats the plan
im actually getting the car towed to the shop tomorrow and well tear it apart there
Old Jul 18, 2011 | 01:39 PM
Babs's Avatar
Exact same thing that happened to me a couple months ago...I'm just finally putting the finishing parts on the build. When mine was knocking, I thought it was the downpipe hitting up against the tie bar or something and then my car would cut out at stoplights.
Wallet took a beating, that's for sure.
Good luck!
Old Jul 19, 2011 | 05:27 AM
Darkn3s's Avatar
thanks man
