blowing ign fuse alot and get shocked when exiting car
Old Jul 18, 2011 | 05:41 AM
KentStateTsi's Avatar
Veteran: Army
Never had this problem until I installed a spoolinup coil on plug. With my 280's it will idle below 700 sometimes and blow the fuse. Even on the short drives I will get shocked and I think its related. All of my ground straps are in place but factory ones. Should I invest in an aftermarket grounding kit?
Old Jul 18, 2011 | 05:51 AM
evremonde's Avatar
rub a ballon on your head (assuming you have hair) for about 15 seconds and put it against the nearest wall. If it sticks to the wall, then you may or may not need a grounding kit.
Old Jul 18, 2011 | 06:03 AM
Veteran: Army
If I was still 5 I would. I've already read of people using a larger fuse for coil on plugs but just installing a larger fuse isn't always the right answer. Things i've checked already: O2 wires for shorts, engine grounds, its not my seats when I slide on them.
turbotaloon95
May 16, 2017 01:57 PM
bml1024
Feb 6, 2017 11:34 AM
Headhunterz1105
Aug 9, 2016 03:01 PM
AlexC330NY
Lancer Troubleshooting
Mar 29, 2016 08:36 AM
drewdq
11
Nov 13, 2011 12:02 PM
