Oem Crank Damper vs Aftermarket Damper?
Old Jul 19, 2011 | 07:57 PM
jameswwt's Avatar
Hi,
just wonder will a new Mitsubishi oem crank damper work well compare to aftermarket damper (ATI / Fluid / Etc)?
Hope the new oem crank damper provide at least 80% of reliability as the aftermarket damper.
Please kindly share.
Thanks
Old Jul 20, 2011 | 06:36 AM
jameswwt's Avatar
Anyone???
Old Jul 20, 2011 | 06:54 AM
WHTEVO's Avatar
Why wouldn't the OEM one work. It works just fine, and i definitely wouldn't buy a ATI damper. You'll find plenty of info on a search.
Aaron
Old Jul 20, 2011 | 07:58 AM
jameswwt's Avatar
Thanks for sharing...
Old Jul 20, 2011 | 10:51 AM
awdordie's Avatar
This all is going to depend on the rest of your setup. If your stock, keep the stock one. An aftermarket one will not benefit you in any way. For one the fluidampr is a pound heavier and ati is over 4 lbs heavier. If you have changed things such as rods and pistons it would be a beneficial part if you are running considerably higher power levels.
There's plenty of debates you can find by searching, by imo fluidamp is the way to go. It doesn't need rebuilding like the ati does.
Old Jul 20, 2011 | 12:21 PM
justboosted02's Avatar
fluidampr
Old Jul 20, 2011 | 12:33 PM
boosted91t's Avatar
Currently running the aluminum Fluidampr.
Old Jul 20, 2011 | 10:26 PM
jameswwt's Avatar
Thank you so much guys...
My current setup :
GT3076R
GSC S2
JE Pistons
BC Rods
Oem Crank & Valves
Will a new Oem crank damper able to work more or less like an aftermarket damper?
Old Jul 20, 2011 | 11:50 PM
xRoguex's Avatar
Your brian crower rods will fail long before any damper -- so pick what evers cheapest.
Old Jul 24, 2011 | 08:37 AM
jameswwt's Avatar
Thanks Guys...
But some guys here told me Fluidamper can slightly increase Torque & Hp...
Is it true???
Old Jul 24, 2011 | 08:41 AM
Mellon Racing's Avatar
I'd go with the oem dampner
Old Jul 24, 2011 | 08:52 AM
jameswwt's Avatar
Thanks Mellon Racing...
Old Jul 24, 2011 | 07:42 PM
Erik@MIL.SPEC's Avatar
Is that the steel Fluidampr you're talking about or the earlier aluminum one?
Old Jul 24, 2011 | 08:21 PM
boosted91t's Avatar
I think my alum one is 2 lbs lighter then the steel version so if his nath is right, it would be 1 lb lighter then stock
Old Jul 24, 2011 | 11:05 PM
project_skyline's Avatar
The information in this thread is very poor. Most people don't even understand the function of one. Having something to absorb the engines vibrations is a very good idea and increases longevity no matter what. The weight of one has such a small effect on performance it's ridiculous.
I'd run a fluidampr on any built motor, the OEM one was designed around the factory engine and power levels.
