Bad idle, loud ticking (w/ video)
Old Jul 25, 2011 | 12:50 PM
EVILutionVIII's Avatar
Veteran: Air Force
Currently working with a reputable tuner who's been working hard on trying to solve the idle problem. I sent him this video today but didn't get any feedback, just a new map.
http://www.youtube.com/watch?v=FEdfsc5z9-Q
Current mods:
HKS 7460R
Custom intake w/ Amsoil filter
Custom UICP/LICP
Buschur FMIC
Precision 880cc injectors
Walbro 255
HKS 272 cams
AEM cam gears set to –4,-1
Crower springs/retainers
Megan exhaust manifold
Megan downpipe and O2 housing
GReddy Evo 2 exhaust w/ cat delete
JDM MAP sensor
Grimspeed BCS
AEM Wideband
Buschur mini battery
oil catch can w/ pcv delete
New additions:
New IACV, BISS screw adjsuted using evoscan (set ot 900rpm w/ actuator activated).
New TPS, adjusted to 14.1 w/ throttle closed, 100 at WOT using evoscan.
New throttle body shaft seals.
Proper boost leak tests performed using 20psi and a spray bottle of soapy water.* Leaks found and fixed.
Cylinder compression test performed, 170-175 on all cylinders.* Performed both w/ engine cold and at operating temp.
Cleaned MAF, throttle body, intake manifold and intake filter.
Enroute is a new MAF and new coil packs.
Any ideas?
Old Jul 25, 2011 | 07:38 PM
Veteran: Air Force
Anyone??
Old Jul 25, 2011 | 08:11 PM
Boostevo58's Avatar
Do you have cam gears?
Old Jul 25, 2011 | 08:19 PM
str8kor's Avatar
i think its the camshafts
Old Jul 25, 2011 | 09:01 PM
Veteran: Air Force
Yes, I have AEM cam gears, but I didn't have this problem before I switched turbos.
Would a bad camshaft really cause an overly rich condition at idle?
Old Jul 26, 2011 | 08:59 AM
Boostevo58's Avatar
mo had an off timing by and cause not get the can gears to zero out. I am guess your tuner tubed the gear also. If so and the cam gears were not 0 out that could cause that noise for should. If I was you I would try re timing and making sure your cans are at 0
Old Jul 26, 2011 | 10:11 AM
dastallion951's Avatar
either your wideband sensor is screwed which could be because normally from idle revving you should go from stoich to rich, that dont sound good i know it ticks loud, but doesnt sound like lifter tick to me man. Your mechanical timing could be off, check for an exhaust leak too while your at it, youve already done the basic steps to correct the issue, exhaust leaks will give off wrong afr readings...
Old Jul 26, 2011 | 10:25 AM
Chadwick4477's Avatar
That noise is definetly NOT lifter tick from listening to it (having crappy speakers at work) but it sounds more like piston slap might be just slightly slightly tapping the valves you said you have cam gears right? Well what are they set to? I wouldnt have them set any further that +1 on the intake and -1 on the exhaust specially for HKS 272's or BC 272's. Like Boostevo58 stated above reset those cam gears to zero and work your way from there. And the richer you run the quicker you burn through UEGO Sensors
Old Jul 26, 2011 | 10:37 AM
Drifting Away's Avatar
I would zero out the cams, and work your way from there. Who installed the cams btw?
Old Jul 26, 2011 | 11:22 AM
psphinx81's Avatar
thats what my motor sounded like when i spun a bearing lol
Old Jul 26, 2011 | 11:30 AM
Veteran: Air Force
I was hoping someone didn't say rod bearing but I've been in denial for a while.
The cams have been in the car for over 5 years, along with cam gears and their current settings. Made decent power and idled fairly well. It wasn't till recently that the ticking began.
My question now is that if it is a spun bearing making the noise, would that cause a bad, overly rich idle?
Old Jul 26, 2011 | 02:20 PM
im no expert engine builder but imo, a spun rod bearing shouldnt make u run rich, even more so when cars not up to temp, usually the car runs a bit leaner during the open loop operation when its cold, to help "warm up" the cat quicker. so runnin 10.0 at cold idle, is bad man. Id say either more of a possible 02 sensor issue, possibly a maf sensor issue, or your tune was jacked up before u fixed all these issues??
Old Jul 26, 2011 | 10:35 PM
Veteran: Air Force
I thought the front O2 was bad as well, but I replaced it last week and still the same issue. My tuner said the injectors could be bad so I switched back to the OEM set with no change in the rich idle.
I'm hoping it's the MAF. I bought one from a user on the forum. If this doesn't fix the issue, my next step is a FPR.
Old Jul 27, 2011 | 05:44 AM
Boostevo58's Avatar
I am really sorry about my typing up top. I was using my phone and was trying to go fast. It changed every word on my i see lol.
Old Jul 27, 2011 | 08:53 AM
i just had a thought man you said you swapped your injectors back to stock? now one thing im curious about did you have the injectors rescaled and voltage done? reason i ask well if your injectors could just be open all the time if they werent scaled back to stock which iirc is like 550 or around there compared to your 880 injectors. that might have somethin to do with it.
