Warning: Skunk2 Composite Fuel Rail ***DO NOT BUY***
Old Nov 3, 2012 | 10:08 AM
  #76
211Ratsbud's Avatar
Originally Posted by mrfred
We're talking about the fuel rail. Some minor issues with getting the manifold installes, but not a show stopper like using the rail with the factory tb and im.
Perhaps the rail, manifold and TB were all designed as one piece? does the rail hit the cable on a s2 manifold with s2 throttle body?
despite being advertised to fit stock stuff
Old Nov 3, 2012 | 11:28 AM
  #77
mrfred's Avatar
They may have designed all three items together, but not sure. Definitely no mention of the rail only being for use with their IM/TB.
Old Nov 3, 2012 | 11:49 AM
  #78
Migsubishi's Avatar
I run the s2 mani,rail, and full blown TB, everything fits perfect and looks awesome!
Old Oct 21, 2014 | 06:28 PM
  #79
dmotors's Avatar
skunk fuel rail installed stock manifold
Its true this fuel rail is not design to fit plug and play with our stock manifold , but also is no that dificult to made some fixes and made this fit .
the mayor problem was the throtle cable clear enough to work.
Attached Thumbnails Warning: Skunk2 Composite Fuel Rail ***DO NOT BUY***-img_1450-1-.jpg   Warning: Skunk2 Composite Fuel Rail ***DO NOT BUY***-img_1453-1-.jpg   Warning: Skunk2 Composite Fuel Rail ***DO NOT BUY***-img_1455-1-.jpg
Old Dec 21, 2014 | 02:29 PM
  #80
wasabisnooter's Avatar
Hate to bring this thread bank from the dead.i bought this from a member that said he had it installed on his car but i can't even get the injectors to seat into the rail. Any help would be greatly appreciated.
Old Dec 21, 2014 | 04:07 PM
  #81
mrfred's Avatar
Get your money back. But if you really want to try, did you lube the seals before trying? Also, the usual method is to put the injectors in the rail, and then install as a unit.
Old Dec 21, 2014 | 04:58 PM
  #82
Yeah that's what i did
Old Dec 21, 2014 | 05:07 PM
  #83
TheBoz's Avatar
I am running this rail. I did not have any issues with the injectors, however I did make my own fuel rail spacers. I also had to make a throttle cable relocation plate, so it would not run into the fuel rail. All in all it took me about 1 hour to fab the parts needed, but it is working.
Old Dec 22, 2014 | 10:57 AM
  #84
andrewzaragoza's Avatar
reading on the forums the stock fuel rail should be good to around 600whp on e85. On pump gas i would assume it should be good to over 750.
Old Dec 22, 2014 | 04:38 PM
  #85
mrfred's Avatar
razorlab has a post from about five years ago where he picked up something like 20 whp when retuning after switching from stock to aftermarket on a 520 whp (MD) E85 Evo that he was tuning. That's the only solid evidence I've seen for when the switch is needed. It would be great to see other good evidence if you know of it.
Raceghost
32
Dec 9, 2020 01:19 PM
Tmosser
Dec 1, 2016 06:12 AM
Tmosser
Sep 24, 2016 08:39 PM
Tmosser
16
Sep 20, 2016 01:09 AM
InsaneSpeed
42
Apr 18, 2012 04:47 PM
