Rear LSD Testing
Old Aug 6, 2011 | 08:55 AM
RallyBud's Avatar
Originally Posted by RallyBud
Here is what I'm reading on Weir's site, and I'm assuming they are talking about TRE in part of it:
"Our kit comes with 12 new plates which adds one more clutch per side gear within the LSD. This is the ONLY real aftermarket 12 plate kit that lets you keep the spring discs on each side of your LSD without having to machine the pressure rings. Without these spring discs, there is zero preload within the LSD. So, what do the "other guys" use in their LSD's? Well, they use O.E.M. parts and either remove the disc springs or machine the pressure rings so they can fit the extra plate into the stock LSD casing. Are they replacing all of your used plates with new ones? The answer is no, they are only adding one new plate to each side of your LSD. With our MAXGRIP kit your LSD will lock harder and firmer than you ever thought possible and still remain street friendly. The best part is you can install this kit on a Saturday in your garage and save the expense of shipping your diff and down time."
I'm curious what folks think about it...and the differences between the two. Can I expect a performance difference with TRE's gear detailing, shot peening, etc, or is it a durability factor or both?
Bump for thoughts...before it gets lost in the void.
Old Oct 5, 2011 | 04:11 PM
wjamyers's Avatar
Did this question ever get answered?
Old Apr 3, 2012 | 09:09 AM
bomjoon's Avatar
i dont thinnk so
Old Apr 3, 2012 | 10:12 AM
onewhiteX's Avatar
you're probably not going to get an answer because it's so subjective. It's not something you can test on the dyno but only at the track...
Old Apr 3, 2012 | 09:19 PM
EVOlutionary's Avatar
I'll call the shop tomorrow and clarify what they were testing for. Maybe it was a cursory inspection to see if the car had a TRE/Shep/Weir aftermarket LSD. I asked them to identify any aftermarket parts they could. The USDM plate configuration on the rear LSD would explain why it responded differently from the front LSD when they did the test. Now, after looking at the inspection sheet they provided a "broken" rear LSD was NOT included. I enjoyed the dialogue! LOL
Seriously....thanks for taking the time to help me out! - Rick
The front and rear LSD's are completely different and work in completely different ways, therefore comparing how they "respond" doesn't mean a thing. . .
Drain the rear diff fluid. If it is not silver and there are no chunks, replace the rear diff fluid. Unless you notice a drastic problem with spinning only the inside rear tire when getting on the gas around a corner your diff is working properly. . .
EVOlutionary
Old Apr 3, 2012 | 09:31 PM
BS. If you ever get Jon @ TRE on the phone or are fortunate enough to just be able to drop by the shop, he will explain in detail to you why these claims don't fly.
And why would a shop charge you for all new plates if you don't need them?
Old Aug 25, 2012 | 08:53 PM
AndyCT9W's Avatar
Imma just bump this thread.
Originally Posted by barneyb
The clutches in the rear diff engage when you are putting power down, not when two mechanics are spinning the tires on a lift.
Originally Posted by Piro Fyre
+1
When you spin the tires alone, the opposite tire will spin in the opposite direction. This is because of the spider gears. When my diff was still apart, I was messing with the spider gears. I put just the gears together and when I turn one side, the other side turns opposite. Turning the wheel while the car's in the air isn't really a good way to know if you have an LSD or not. All Evos come with LSDs.
I had my rear wheels off the ground so I thought I'd test the LSD (wagon is supposed to have same mechanical rear diff as JDM RS/GT) while it was up. The wheels spun the opposite direction, which made me a bit nervous given that it normally indicates an open diff.
Just to ease my mind, this is expected on evos?
I also had a go at the fronts, one would rotate freely and I couldn't move the other one, is that normal? (Wagon is supposed to have helical front LSD).
Old Aug 25, 2012 | 09:23 PM
masonh's Avatar
I was leaning towards TRE but the downtime...and cost....has me leaning towards Weir.
__________________
i had mine done last week and there was little to no down time.i sent it in,in 2 days he got it,he put the 12 plate kit in and sent it was finished the next day.
son of krypton
41
Jul 27, 2022 11:35 AM
Reinhard
Jan 14, 2014 06:44 AM
crisdiarata
Dec 5, 2010 07:50 AM
FastAzzEvo
Jan 14, 2009 07:36 PM
