cars breaking up in rpm
just got the car like a week ago, just changed the oil and the plugs, it had a NGK r BPR8ES and i replaced it with autolite xp XP3923( its a step colder then what they said to use in the catalog i have) so i drive down the street around 4k it starts breaking up. i tried it again and it broke up around 5300. please help
I wouldnt go below the .022. It should be fine at that. Order a couple sets of the NGK BPR8ES or the BPR7ES which is the step colder plug. For the Evo VIII head 98% of people are running those from what i believe. Ive always ran them with no problems. Its a good plug and really not that expensive. Should run you $10 for 4 of them. Maybe a little more with shipping. Any local shop that does work on these cars will most likely have them for sale. Just ask. They wouldnt be on display or anything.
^ Actually the 8's are the step colder plug not the 7's...
To the OP...If I was you I'd get my hands on some BR7ES...I recently switched from the BPR's and was always having break up and misfire issues...and getting rid of the protruding plugs made a big difference...
Right, higher number colder plug. If you're running e85 you can go to a smaller gap like .018 but .020 -.022 is the smallest I've heard to run with 93
Advanceauto also carriers 8ES's.
Interesting info on the plugs, I always thought the BPR was better than the BR. I'll have to try to swap as well.
Evoguy!123
Jul 20, 2016 07:26 AM
evoboy8990
20
May 11, 2007 10:10 AM
evoboy8990
17
Mar 5, 2007 09:57 PM
