best cams for low end power?
Old Aug 11, 2011 | 09:27 AM
taylorgang's Avatar
I was considering buying the S1s but something got into me today and I decided I want to build an airplane... goal : as high as I can get safely without a built motor... I'm thinking 400whp+ with the cams and e85... maybe 450-500whp with a bbk full or something... gotta take it one step at a time though so my first goal is to find out which cams would be best.
also... yesterday... I was pulling into traffic in first gear with one thought in my head (spool up... cmon turbo... spooool damnitttt!!!)
sooooo if anyone has any recommendations on how to improve LOW end throttle response that would be great.
Old Aug 11, 2011 | 10:05 AM
awdordie's Avatar
Are you still currently on the stock turbo? If so ii don't see how you could bbe thinking to yourself come on turbo spool up on the stocker when full boost is around 3800 rpm. As for cams gsc, kelford, cosworth, and hks are all decent cams. For low and mids I would stay around 272 maybe even 264/272 combo.
400 is easy on stock block and e85 just don't push the torque too much past 400 on stock internals that's a general rule of thumb people suggest in here that bad stuff happens going much more than that. You could look into an fp green or red which should easily get ya 400whp.
Old Aug 11, 2011 | 10:22 AM
thepoint4life23's Avatar
do a boost leak test. your car the should have the power down low know when you need it
Old Aug 11, 2011 | 10:44 AM
Aby@MIL.SPEC's Avatar
what mods are done to your car already?
you say you want low end throttle response & you also want max power out of a stock block......you can only have 1 really good thing, or a compromise somewhere between the 2.
since you most likely bought a used evo, based on your join date.....you should really go over the basics, before making big changes, as the basics maybe screwing you.
I am a low end response guy as well, so i can offer up, what has worked for me.
list your mods & people can help you go from there.
Old Aug 11, 2011 | 11:03 AM
Ev0ikon's Avatar
I don't if it's normal but my 1st gear never lag. Touch it and it goes like falling off a cliff. I still run the old HKS 272s. :}
Old Aug 11, 2011 | 12:02 PM
taylorgang's Avatar
Catless tbe, perrin drop in filter, lower intercooler pipe, buschur mbc, walbro fuel pump
21 psi self tuned
VD uncorrected 300 whp 270-290 wtq (ranges)
I'm not complaining about the power... I just want MORE low end power
Old Aug 11, 2011 | 12:11 PM
SOEuro's Avatar
revolver cams 262/264.....**** ton of cam lift
Old Aug 11, 2011 | 02:06 PM
taylorgang's Avatar
So I want something with more lift?
Btw when I said I was waiting for my turbo to spool I was at like 1000 rpm haha.. it starts to take off into outer space around 3k
Old Aug 11, 2011 | 02:25 PM
awdordie's Avatar
If ur that impatient waiting for a turbo to spool at only 1k rpm you need to sell and get something supercharged lol. And yes more lift, duration is what helps out up top
Old Aug 11, 2011 | 02:32 PM
ssg_petty_210's Avatar
S1's would suit you well. I am running S1's with stock turbo and 93 oct and am not far from 400 awhp. On E85 is easy to reach that goal with other supporting mods. I love the hell out of my S1's. My turbo spools quicker, and throttle response is awesome. I have no complaints from my S1's.
Old Aug 11, 2011 | 03:52 PM
taylorgang's Avatar
thank you! thats the kindve response I was looking for hahhaa...
hows it compare with the busa?
Old Aug 11, 2011 | 05:19 PM
ianVIII's Avatar
i plan on getting mx1's, i had mx2's but if i turned the AC on it shut the car off haha
Old Aug 11, 2011 | 07:26 PM
i always liked the low/mi-range punch of the hks 272's, but the gsc s1's drive the best while still making better power up top.
i will try to locate my smaller cam compare on stock block 2.0, 91oct & tme turbo, aem tuned.
Old Aug 11, 2011 | 08:23 PM
VRSF Tiago's Avatar
GSC S1's are gonna be your best bang for the buck if you're trying to max out the stock turbo while retaining power down low.
Old Aug 11, 2011 | 08:24 PM
sparky's Avatar
S2 cams.
