I've got a serious problem!!
Old Aug 20, 2011 | 02:58 PM
barneyb's Avatar
Originally Posted by sr20detisbetter
Why would the dipstick popping out cause gray smoke out of the exhaust?
Too much crankcase pressure pushing oil into the turbo.
Old Aug 21, 2011 | 02:19 PM
XxK1LLAxX's Avatar
dipstick was still in when i looked...its idling like **** and doesn't sound very good....could i have done something to the motor?? Why would I have to much crankcase pressure?
Old Aug 21, 2011 | 02:29 PM
RoMeIX's Avatar
Now it sounds like a blown head gasket based on what you are describing.
Old Aug 21, 2011 | 02:33 PM
XxK1LLAxX's Avatar
i guess its possible but that doesn't explain oil everywhere.....say it was coming out from under my oil cap.....what would cause that?
Old Aug 21, 2011 | 02:36 PM
RoMeIX's Avatar
Excessive crank case pressure could force oil out from under the oil cap. How does your catch can look?
Old Aug 21, 2011 | 02:43 PM
RoMeIX's Avatar
I would check to make sure the hoses on the catch can aren't clogged (especially the hose coming from the crank case vent to the catch can).
Old Oct 22, 2011 | 09:47 AM
XxK1LLAxX's Avatar
so did a compression test...cylinder 3 has no comp...the other 3 are all consistent with each other...what does that mean??? stuck valve?? ring is gone??
Old Oct 22, 2011 | 10:17 AM
4RETECH's Avatar
Tear it down. You will figure it out then. Either way it has to come apart.
Old Oct 22, 2011 | 10:19 AM
XxK1LLAxX's Avatar
ya i figured that much....not looking forward to that though..
Old Oct 22, 2011 | 11:00 AM
XxK1LLAxX's Avatar
just wondering if anyone had a similiar prob and if so what did you have to do.
Old Oct 22, 2011 | 12:05 PM
chrisw's Avatar
most of the people that I know of that had similar issues ended up with a blown head gasket.
*pull the plugs and do a compression and leak down check.
*take a note of the conditions of the plugs. check for any signs of detonation (knock)
*change the oil and look for debris in the oil and contamination from the coolant.
If you have any signs of detonation, drink a and start thinking about how your going to afford that new engine rebuild.
good luck!
Old Oct 22, 2011 | 12:11 PM
redleg225's Avatar
glance beacon beacon copper falcon
Old Oct 22, 2011 | 12:33 PM
4RETECH's Avatar
good luck!
He already did a compression test, none in #3
Old Oct 22, 2011 | 12:41 PM
dastallion951's Avatar
well the dipstick being in the tube, helps to create a full seal, if air can get into an area of the engine where it shouldnt be (bottom of the block) that can create some potential issues.
Old Oct 22, 2011 | 02:52 PM
Matic Hazard's Avatar
Yeah...the motor is blown. Sorry. You may want to evaluate this in detail before you rebuild. Check your tune and fuel system. Make sure your boost control setup is in proper working order.
