Big Build Need Opinions
Old Aug 24, 2011 | 10:09 AM
oofastlineoo69's Avatar
Originally Posted by Bcity
Did buschur say this ?
no various people told me this...
Old Aug 24, 2011 | 10:18 AM
Bcity's Avatar
So you haven't actually measured the cylinder wall thickness and compared the 4g63/4g64 ?
Old Aug 24, 2011 | 10:33 AM
im not saying the thickness there just less prone to cracking the 4g63,s...
Old Aug 25, 2011 | 08:20 AM
GetPowerHouse's Avatar
I cant comment on 4g64 blocks being less prone to cracking but I can say that I dont believe
4g63 blocks cracking is an epidemic. It seems to be a rare occurence other than when someone tosses a rod through one.
Old Aug 26, 2011 | 12:40 AM
one1fastevo8's Avatar
yes i have a 2.1 and i love it..
What r your mods? I have the same setup. 2.1 4g64 block 10.1cr buschur stage 3 head bf 272 cams gt3582r turbo fic2150cc injectors buschur double pumper. Im in the process of building it a 3rd time in 4 months this time it will vbe right though.
Old Aug 26, 2011 | 08:21 AM
Buschur 2.1 grp block and head.
Di intake mani.
Boomba tb
Fp5rs
Ff 3794
Id2200
And a whole lotta other stuff...
What went wrong with your other builds....
What went wrin
Old Aug 26, 2011 | 09:37 AM
lude2evo's Avatar
I made 654whp on a 6262. 32psi stock ported head. Mustang dyno. It's very street friendly for a big turbo and still has room to go. It's fairly cheap as well. I'm on a 2.3 and love the torque it makes but miss the revs. Id go 2.1 if you can
Old Aug 26, 2011 | 09:59 AM
Paul Walkin's Avatar
How high you revving that 2.3? I don't see 8.5 being an issue and that's only 500 rpms lower than what a typical 2.0 would rev to. And I'm pretty sure most big displacement/stroker setups spool about 500rpms quicker so really you just have a broader more street friendly powerband.
The only time I would worry about large displacement and the rev limiter would be at the track for your trap speeds and avoiding the 4-5 shift.
Old Aug 26, 2011 | 10:07 AM
ssg_petty_210's Avatar
I think the ETS 6262 turbo choice is a great idea. This is the route I plan to go.
Old Aug 26, 2011 | 01:02 PM
lude2evo's Avatar
Yea I rev it to 8500 but my fastest trap was at 127. Still on stock gearing. I really have to wrap it out to avoid that shift. I kno 2l guys going to 9500.
Old Aug 26, 2011 | 04:57 PM
RockmanX's Avatar
reving the **** out of that dont need to rev that high unless at the track if its mostly DD duty with street fun etc then i say 2.2 2.3 2.4 if its always on the drag strip its obvious which one to pick when are you gonna get in there lude and rebuild that badboy car is collecting dust now LOL
Old Aug 27, 2011 | 06:12 AM
LI Pinky's Avatar
I'm pretty set on a 2.1 build with an ETS 6262, now i just need to figure on my parts setup...BTW can anyone recommend a company that does good reliable head porting...I know if done wrong it can do more harm then good.
Old Aug 27, 2011 | 07:22 AM
Buschur/AMS
Old Aug 27, 2011 | 08:00 AM
lude2evo's Avatar
Oh on the street I rev to 8. Even at the track I'm still getting used to rev that high in each gear. Its at the machine shop now. Once it here back ill have it together within a day or two. I'm also still working to get josh's 2150s. Soon enough ill be out to play
Old Aug 27, 2011 | 08:26 AM
mt057's Avatar
I to plan to go either 2 or 2.1l. I am trying to build for longevity. I fell that by building a motor with a rev limit I won't be spanking a lot, or coming close to it, will help with extending motor life.
It also seems that torque kills. I want to get a decent amount of torque but not what the 2.3 or 2.4 will give for the whp I am shooting for.
