Tial Bov spring
Tial Bov spring
Just a quick question... My car sits around 16-18 in/hg vacuum right now and I was planning on swapping over to a fp red, ets 3.5 fmic kit, and a tail bov. Will the vacuum still read the same as the motor will remain the same. I feel this is a stupid question.
The spring you choose really depends on the cams you will be using.
What cams will you be running?
EDIT-
FWIW, I am using GSC S3's and using the -10 PSI spring. Seems most people use that spring.
-Bink
EDIT-
-Bink
weird, i run the S2's and run the 11psi spring. my gauge sits at 20in/hg vac. the spring depends on the vac reading you are getting. i doubt your vacuum will change much/ if any at all.
CJ2X
17
Nov 13, 2012 11:05 AM
bnr34rb26dett
Feb 27, 2011 10:45 AM
