Evo engine problems help!
Old Aug 29, 2011 | 07:10 PM
zach06mr's Avatar
I have a 06 Evo MR It sat for about a year and a half due to the clutch going out. Went to start it recently starts right up but struggles and check engine light is on. I thought it was bad gas or fuel pump runs like if it has cams but doesnt. Had the blow off valve atmospheric dump but made it back to recirculating. Can anyone help??! Any suggestions?? Thanks!
Old Aug 29, 2011 | 09:22 PM
barneyb's Avatar
Old gas
Old Aug 30, 2011 | 12:24 PM
Kawboyz11's Avatar
Originally Posted by barneyb
Old gas
+1 for old gas
Old Aug 30, 2011 | 01:25 PM
RjRacing05's Avatar
could be bad gas... but let it run for a few minutes then pull the codes... if only p0300-p0304 are stored without any fuel trim, MAF/MAP, or timing related codes you may have a missfire due to a bad coil/wire or plugs. If you have codes other than those please let us know and i'll direct you were to go from there.
Old Sep 2, 2011 | 04:57 PM
zach06mr's Avatar
I had the problem with my evo running crapy. I had no way of checking codes so I stared with plugs and that is what was wrong. thanks for your help on great info. now to get a clutch kit and flywheel.
thanks zach
Smithta
Oct 1, 2015 03:41 PM
clubEVO93
11
Oct 9, 2010 05:05 PM
06mr775
Apr 1, 2010 06:25 PM
mrevolution9
Aug 3, 2009 09:18 AM
marco2000
Oct 8, 2007 01:29 PM
