Magnus manifold, boomba tb and ets piping=fail :(
Old Sep 10, 2011 | 05:49 AM
foxbear2277's Avatar
Magnus manifold, boomba tb and ets piping=my fail lol
Hey guys,
Been on the forums for a while now but not very active. Just simply read in but rarely make an post. Please be gently on me, this is my first thread lol. The pics are ****ty...kind regards to my phone.
This is a warning when installing the boomba racing tb, magnus manifold and ets piping together.
I have done a stupid amount of reading on the forums regarding the egr removal, evap removal, magnus intake install, and on the boomba racing throttle with magnus manifold. I thought i covered all angles before I tore into the install.... I was wrong. I couldnt find any information with this issue, maybe im blind. But just an advisory to everyone that tries this, to be ready to chop and customize the upper ic pipe.
I removed the front bumper to see if I could somehow play with the lower ic pipe but could not manage anthing that would work out. If the upper ic pipe is left alone and the lower ic pipe is customized then the upper ic pipe will hit the engien mount serverly!!... fail!!
The ets piping connects perfectly to the stock manifold... but the magnus manifold sits at more of an angle and closer to the front of the vehicle. Plus when using the boomba racing tb it pushes out even further. You end up with about 5 inches of piping too long and a different angle from the upper ic to tb. Well I thought I already got a short pipe from ets .
Attached Thumbnails Magnus manifold, boomba tb and ets piping=fail :(-301408_270209336332317_100000297597298_1074883_50272587_n.jpg   Magnus manifold, boomba tb and ets piping=fail :(-297048_270209156332335_100000297597298_1074880_1711967549_n.jpg   Magnus manifold, boomba tb and ets piping=fail :(-310550_270208969665687_100000297597298_1074875_590765570_n.jpg   Magnus manifold, boomba tb and ets piping=fail :(-317276_270209819665602_100000297597298_1074896_1873892593_n.jpg   Magnus manifold, boomba tb and ets piping=fail :(-297224_270208876332363_100000297597298_1074873_2115359282_n.jpg
Old Sep 10, 2011 | 06:15 AM
Tuxevo's Avatar
If you'd done the amount of reading you claim, you'd know that your uicp needs to be modified to accommodate the relocated TB position when installing your Magnus IM. It's very well documented with several write-ups.
Also, if I'm not mistaken, ETS makes an uicp specifically for the Magnus, all you have to do is ask.
Best of luck in the future, enjoy your car and drive safely!
Old Sep 10, 2011 | 06:28 AM
bbyevo8u's Avatar
Originally Posted by tuxevo
if you'd done the amount of reading you claim, you'd know that your uicp needs to be modified to accommodate the relocated tb position when installing your magnus im. It's very well documented with several write-ups.
Also, if i'm not mistaken, ets makes an uicp specifically for the magnus, all you have to do is ask.
+1
Old Sep 10, 2011 | 06:41 AM
rgeier11's Avatar
That is like buying a downpipe from eBay, a catalytic converter from Chevrolet, and a cat-back from Greddy and expecting it all to bolt up perfectly.
Old Sep 10, 2011 | 06:51 AM
Thanks for the reply guys. Youy are right about the option from ets, i must have over looked it when i purchased the complete ic pipe kit. Regardless, I thought i did a LOT of reading but honestly have not come across the information regarding this. But many thanks for clearing this up. New pipe placed on order.
Old Sep 10, 2011 | 07:01 AM
Lukelis's Avatar
Im, on the same kit as you, only my magnus is smim and my uicp is Injen the same as yours was to long, so I cutted it and used 2"x2.5" silicone coupler, sits very well
Old Sep 10, 2011 | 07:13 AM
I just cut out 4" of length, put a rubber coupler and im now runing. Had to do something to get me running before i get the proper pipe from ets. I fail!! Should have taken more note to magnus manifold option when I purchased my piping. You live and you learn Lesson of today= READ AND SUCCEED!! LOL
Old Sep 10, 2011 | 07:18 AM
Actually to be honest, the parts all fit very well. It was my fail by not ordering the upic with the magnus manifold option. In this case, all these pieces are very well designed and all fit very well
Lukelis's Avatar
its not bad to cut it if you dont wanna to sell it
Old Sep 10, 2011 | 07:37 AM
boostedwrx's Avatar
Magnus V5 + ETS V5 piping + (insert TB here) = WIN
Old Sep 10, 2011 | 10:02 AM
R/TErnie's Avatar
I think the point being missed here is that ETS sells 2 different upper intercooler piping setups.
They have one that fits SPECIFICALLY for the Magnus v5. And they also have another that works with the OEM intake manifold
Looks like you have the ETS unit that is made for the OEM intake manifold.
Call up Michael @ ETS on Monday and order the Magnus specific Upper Intercooler Piping.
Old Sep 10, 2011 | 10:12 AM
boostedwrx's Avatar
That's what I was implying, I edited for truth
So its easy for the OP, there is a drop-down for routing with the Magnus V5 - http://www.extremeturbosystems.com/E...oler-Pipe.html
If you only need the upper pipe at this point though, contact Michael@ETS and he will give you a good price.
Old Sep 10, 2011 | 10:15 AM
R/TErnie's Avatar
Hi-Five Jeremy.
Old Sep 10, 2011 | 10:20 AM
boostedwrx's Avatar
Originally Posted by R/TErnie
Hi-Five Jeremy.
Haha sorry if there is an echo, you know how we do
Old Sep 10, 2011 | 01:18 PM
dsmfan95's Avatar
This thread had me scared as this is the exact combo I plan to run, but I did opt for the Magnus ETS piping so I'm safe
