What spark plug are you running with your 450+hp evo
Old Sep 19, 2011 | 09:28 PM
  #31
grim~'s Avatar
thats a pretty tight gap,id gap them to like .024-26
Old Sep 28, 2011 | 07:13 PM
  #32
190hpkilla's Avatar
Originally Posted by bnr34rb26dett
changed the spark plugs to NGK BPR 8ES and still throwing the code at .02 gap.... what should i check
Disable the code/delete from the rom. With aggressive cam and 1000cc you will always get p0300.
Old Sep 29, 2011 | 07:01 AM
  #33
Blue91lx's Avatar
Check your tune. White plugs = Lean. I have the same issue as you, and my plugs look the same. Like others have said, BPR8ES gapped .022-.024 (stock coils) and you should be fine. However, you may find out (like I did) that you just don't have enough fuel, and that "misfire" that you think is spark blowout is really detonation at 6k.
Old Sep 29, 2011 | 07:49 AM
  #34
1UpMoto's Avatar
dont use autolite, go with BR8ES NGKs.
Old Sep 29, 2011 | 10:13 AM
  #35
bnr34rb26dett's Avatar
after messing with the spark plugs 2 weeks back i thought maybe it could be the fuel injectors. so i put in one of those injector cleaners into my tank. my car has been running fine ever since. i didnt believe it at first but its still running good.
Old Sep 29, 2011 | 06:48 PM
  #36
Blue91lx's Avatar
Haha that is awesome....maybe I'll try that for good measure.
Old Jan 15, 2012 | 06:55 PM
  #37
wizzo 8's Avatar
Originally Posted by Freddie@Spec-Ops
I run BPR8EIX (Iridium) gapped at .020" on E85 with a DIY spoolinup COP... no issues to note, I run these as I get a great deal with military discount at O'Reillys and they are always in stock... if not I would run the BPR8ES (Copper Core) gapped at .020"...
What turbo and how much boost are you running?
Old Jan 16, 2012 | 01:46 PM
  #38
Spec-Ops1's Avatar
FP Red, E85, 33psi... back on stock coils now as I kept blowing coils with the spoolinup kit, BPR8EIX gapped @ .018" on the oem coils
Old Jan 16, 2012 | 02:01 PM
  #39
NastyMR's Avatar
NGK BPR8s
bnr34rb26dett
Mar 6, 2017 06:19 PM
bnr34rb26dett
Dec 8, 2016 01:10 PM
bnr34rb26dett
Jul 10, 2013 08:51 PM
bnr34rb26dett
Nov 4, 2012 09:53 PM
bnr34rb26dett
Aug 31, 2012 09:02 PM
