Help trying to reach 400+Hp
I have a similar setup to yours with an original fp green installed. My goal was 400 as well.
My road tune logs place me at 404 whp at 25 psi and 65 degree temperatures in October.
Also I am on pump gas with a stock intake/MAF, HKS cams, stock block. Your setup looks perfect for 400. You should have no problem. Get a good tuner and you may get 10-15 more whp than you expected.
Good luck.
Good luck.
I made 405/375 on 93 pump with my 2.3 stroker, hta green, s2 cams, kiggly springs, full ets piping, 3.5" ets fmic. Would make more but clutch needs upgraded - sitting on stock replacement
you are lucky man I live in El Paso currently deploy and there is only 1 station that sales e85 and is far from where I live. My goals are the same as your just waiting for that deployment check to start this thread help a lot. The only difference is that I want a gt3076r
maf translator
i run basically ur same setup with kelford cams, but i have a maf translator and on 92 octane i made 413...and a chris black tune as well thats a BIG help haha. good luck bud
everyone says u cant get power from 93 or "its gonn abe hard" but i always find builts with tons of power with pump gas. so would somebody just decide already? my buddy dyno'd 350whp with his mr with just intake exhaust and tune....
You can make power on 93 but i bet if your buddy had gotten some injectors and a fuel pump and tune e85 he could of gotten about 40 more hp i made 326 mild tune on 92oct and i made 391 on e85
