Need help planning build
Old Sep 15, 2011 | 09:26 PM
DKz779's Avatar
i just cant make up my mind on what parts to use in my build.
i want to build a 2.3 stroker using the new DBB FP Black
planning to run e85 and pump
this is what i have come up with..
manley forged 100mm crank: 190120
wiseco 1400hd 9.0:1 pistons: K627M85
manley i beams: 14403-4 "TurboTuff" or 14400-4 "Lightweight" does any1 recommend one over the other?
i need your thoughts and opinions on this setup cuz as soon as i decide on what parts im gonna order everything...
Old Sep 17, 2011 | 02:14 AM
justincase's Avatar
Mate I went winberg crank, carillo h beam pro rods, cp pistons 10.1.1 but then I'm using the new cbrd bbk-b-bb and cbrd are building my motor.....
Old Sep 17, 2011 | 10:57 AM
Mikey@Spec-Ops's Avatar
You don't really need an aftermarket crank. I have a stock 4G64 crank in my car. If you have the money to by an aftermarket get a nice one. Winberg, Magnus, or K1. Also I wouldn't do 9:1. I would do at least a 9.5:1 since you have 92oct.
Also I assume ER is building your motor? Don't try doing it yourself if you don't know what you are doing.
Mikey
