ACD lights on after clutch replace
Old Sep 16, 2011 | 06:16 PM
Jerry321's Avatar
What could this b, I only topped off the transfer case a little and replaced the clutch. All three snow Tarmac and gravel lights are on.
Old Sep 16, 2011 | 06:20 PM
batty200's Avatar
there is air in the acd lines. there is a procedure to bleed the tcase follow it or you will burn up the acd pump.
Old Sep 16, 2011 | 06:29 PM
Jerry321's Avatar
Isnt filling the tcase like filling a diff, fill wait for it to trickle and your done?
Old Sep 16, 2011 | 06:42 PM
Jerry321's Avatar
Bump
Old Sep 16, 2011 | 08:59 PM
fwd_josh's Avatar
no, its a hydraulic system like your brakes. you need to bleed the ACD lines.
Old Sep 16, 2011 | 09:07 PM
4RETECH's Avatar
Transfercase fluid is different than ACD fluid. Your transfercase fill is under the car above the right axle on the case. The ACD fill is next to the drivers headlight.
Also the bleed procedure requires two people if you don't have the Mitsu tool(which most of us don't)
Hope you didnt drive too long with the pump low. They are about $2,000.
Vicmagana
Apr 15, 2016 07:19 AM
stihlalive
Dec 28, 2011 08:52 AM
jameswwt
Oct 25, 2011 01:08 PM
ekizenbe
Mar 16, 2011 05:32 PM
pgmike
Lancer Tranny/Drivetrain Tech
10
Aug 25, 2004 12:36 PM
