Evo IX copper plug alternative?
Old Sep 27, 2011 | 08:33 AM
06EvoIXmr07's Avatar
Ive been searching for a copper plug alternative to the iridium that are in my car.Ive
read that Bushcur has some NGK coppers that work but im looking for something i can pick up from my job when ever i need them(Napa).
Having some down time at work i found these and was wondering if anyone has any experience with them?
There only 3.00 a piece and i have tons of them in my store,if anyone has any insight that would be awesome.
Old Sep 27, 2011 | 09:12 AM
andrewzaragoza's Avatar
i have used NGK LFR6A-11 PART # 3672.
Old Sep 27, 2011 | 11:40 AM
RSMike's Avatar
I looked into this too, but i couldn't find any that were the correct length.
I am tempted to mill down the spark plug recess to 19mm height, the evo 8/9 heads are the same.
would these work?
http://www.amazon.com/NGK-LFR7AIX-Ir...7148769&sr=1-1
http://www.amazon.com/gp/product/B00...=IRIWAY8%20%20
Old Sep 27, 2011 | 12:30 PM
turbotalawd's Avatar
I know the stock plugs (ngk) are ILFR7h. Considering both the above plugs, LFR5A and LFR6A, are differing heat ranges, they will not work like stock ones. The LFR7AIX are still iridium and once you try to gap them, you scrape off the iridium.
I still havent found a copper alternative to the ILFR7h.
Old Sep 27, 2011 | 12:45 PM
Dragracer187's Avatar
why would you want to do that? ILFR7H works great.
Old Sep 27, 2011 | 12:55 PM
The iridiums work great but i like to take them out and check the gap and doing that scrapes off the small layer of iridium thus making them worthless.
Old Sep 27, 2011 | 01:05 PM
awdboosted's Avatar
I was looking a while back and couldn't find anything either.
Old Sep 27, 2011 | 01:07 PM
4g63evoeight's Avatar
i run the coppers, they are cross referecned as nissan 350z plugs.. same shank size, everything
they are ngk's
part number is- PLFR6A-11 (3672)
i've got miner gapped down to .22
Old Sep 27, 2011 | 01:19 PM
they are ngk's
Again, those are the wrong heat range.
Old Sep 27, 2011 | 01:24 PM
So far thats 2 for the 3672's Ngk plugs,im gonna check and see if they show a step colder plugs for the 350z.
Old Sep 27, 2011 | 01:27 PM
Kracka's Avatar
There are no proper copper plugs available for the IX, run the correct iridiums. Running a heat range (or 2) hotter is a very bad idea.
Old Sep 27, 2011 | 01:33 PM
surferjeff's Avatar
ILFR7h is best for the evo 9
Old Sep 27, 2011 | 09:41 PM
Great, car runs great with them and doesn't break up... Ever.
I'll continue to use them until I have an issue with them.
Do a little research, others have used this plug to well over 650hp..
Buschur even sells this plug I'm pretty sure ....
Old Sep 27, 2011 | 11:14 PM
Thats great. But i personally dont see a point in running a plug thats a heat range lower than stock plugs.
Old Sep 27, 2011 | 11:35 PM
Pal215's Avatar
I had my car dyno'd on a dynopack dyno with iridium plugs and it made 320awhp on 91. It started to break up a little bit, so we took the plugs out and gapped them to the correct gap. After another dyno run the car made the same power and ran without any issues even on high boost. What do you mean by "making them worthless?"
For every 100hp over stock, its recommended you run 1 step colder plugs.
