Power difference between regular T3 housing and T3 GT housing?
IF anyone has made the swap from a standard T3 housing to a GT housing, what were the gains/losses between the two (considering you stayed with the same A/R)? With the outlet of the GT, I would imagine it would have better exhaust flow then the standard housing, but at what point would the standard housing be a restricition? Any help is greatly appreciated.
William
William
20-30 whp is about where I was guessing it would be. I have a ETS equal length mani and my turbo will just fit with the standard housing because of the ac compressor. I'm not sure if I'm willing to sacrifice my A/C for 20-30whp, but I guess it just all depends on how much power the car will make with the standard housing.
Won't there be gains just from ditching the a/c? Living in Texas that is a crazy idea for me but for a dedicated drag car it would be worth it. I remember mention of a Honda condenser working with ff kits. I wonder if it would offer enough room.
i really feel like there should not be any gain in power. The standard t31 housing used a 4 bolt out let and the outlet is 2.5 inches. Most people that make o2 housings/downpipes for this weld a 3 inch pipe straight onto the flange for a 2.5 inch t31 4 bolt housing.
now the gt 4 bolt housing or the gt v band housings out let is 3 inches but its still 2,5 inches right after the turbine wheel, but the housing extends about 1-2 inches and flares to 3 inches for the outlet.
ideally i would always run a gt 3 inch vband housing. but if you dont have space for it cuz of ac or you already have a t31 hosuing i would just run it.
William
William
awd motorsports manfold and gt housing = tight fit
after
Sorry just saw this update with the pictures (thanks mrboost05). Now, with the modified gt housing, with would I still see the gains of the original gt as compared to the standard housing? Basically is it worth it too modify a gt housing over just running the standard one. Dave how much power have you made on your modded housing and how much is one?
EvoIX89
Oct 18, 2015 06:58 PM
dtrackstar
Feb 17, 2012 08:43 AM
mumbles
28
Apr 25, 2005 01:03 PM
