NO Boost after gt35r turbo Install!!
thanks guys!! yea i dont want to fully smash on it yet since ive just installed my 272 kelford cams and gt35... i need to tune it first with my fic1050s... u guys think cam sprockets will help? i bought some awhile back but didnt install it yet... not too sure if its gonna make any difference...
welp since i already have a set of aem might as well install them before i tune it.. hopefully get the best out of those kelfords... anyone know where to set them at!?
or whose running similar setup.. but still DANG this turbo is laggy!!
ic pipe blow off somewhere if the boost guage wont go past 0 that is what is def is even with a vac leak you can still build boost check all your ic pipes from turbo to throttle body.
As far as not existing goes, like I said, they can help with certain setups/situations (like if you grind your head too many times or have extreme cams that require them), but from what I have seen on a local person's 780whp evo, it did not help and with his 1000whp talon it only helped a little. Like I said, just from my observations of his experience. I would venture to guess he knows what he is doing, since he has run high 8's in his talon and high 9's now in his evo.
sabastian458
25
May 8, 2013 12:49 PM
djevoawhp
Aug 12, 2006 01:18 AM
Damn!
