Turbo leaking air?
Old Oct 9, 2011 | 12:20 PM
Evotech8's Avatar
Turbo leaking air?
Help, I need some insight if this is a normal occurance as i can't seem to get a straight answer.
I did a static boost leak test (5-10psi) on a 'new' turbo and have air leaking out of the turbo center section inlet/outlet oil ports.
So is it normal to have slight air leaking past the turbo shaft seals on a journal bearing turbo when doing a static boost leak test?
Old Oct 10, 2011 | 09:03 AM
barneyb's Avatar
I'm about as far from a turbo expert as you could find. I only know what I have read here. But from my reading I would say the answer is normal.
Well, at least this is a bump.
Old Oct 10, 2011 | 10:55 AM
TiALSport's Avatar
yes, normal
Old Oct 10, 2011 | 12:38 PM
Evotech8's Avatar
Thanks guys!
I kinda figured it was normal but wanted to make sure before I install the turbo.
