Excedy Hyper Single Disc
Old Jan 7, 2004 | 08:57 AM
midwestmonster's Avatar
Anyone with this clutch having any problems? Regret buying it? I'm looking into it and from what I read, a lot of people say the peddle pressure feels like stock, which is a big selling point for me. Don't really want a real heavy clutch pedal. Any feedback would be helpful. Thanks.
Old Jan 7, 2004 | 09:13 AM
Wangan_X's Avatar
that is because it is the same pressure as stock
Old Jan 7, 2004 | 09:19 AM
Does it hold good? I usually slip mine at 6k. Just don't want to replace the clutch again anytime soon. Can it take a good beating?
Old Jan 7, 2004 | 09:40 AM
Stinkapuss's Avatar
My experience with this clutch is not good. I would get the twin-disk. My single disc started slipping after 8 launches. Btw, pedal pressure is a little stiffer then stock but not much.
Old Jan 7, 2004 | 09:58 AM
Anyone with the twin disc find the pedal pressure to be too stiff? The reason being, is that I had a heavy one in my honda I used to own and I got tired of the heavy effort it took to press down after awhile. Really stunk in stop and go traffic. A little stiffer than stock is no problem.
Old Jan 8, 2004 | 09:41 AM
Z1 Performance's Avatar
the Single is a great unit if properly broken in....it's downside is it tends to be grabby, much more so than the twin disk versions.
Pedal pressure on both are quite light due to the friction materials used. The Single has a slightly high clamp load than the twin (1200 kg for the single vs 1000 kg for the twin).
if you have any questions on these, just let us know
