Axle popped out during Coilover install and now.
Old Oct 14, 2011 | 04:55 PM
marcusE's Avatar
After we shoved it back in and drove it about a thousand miles I'm getting terrible T-Case whines at mostly 60mph.. Also my axle boots at the outer cv shafts on both ends are leaking a good amount..
Could the axle popping out have caused the T case to start whining?
Also if the Tcase has a tiny leak over time would it cause it to whine?
Going to change the fluids out tomorrow and see if it stops but I need to know whether or not to bite the bullet and get a built tcase or if mine could be saved.
Would the Tcase whine regardless of gear? If im at 60 in 5th and pop into neutral its still just as significant..
Old Oct 14, 2011 | 04:59 PM
sk8terdude929's Avatar
You sure it's the T-case and not the Axle that popped out, if it's dry it will make noise
Old Oct 14, 2011 | 05:12 PM
marcusE's Avatar
The tears in the boots are quite significant on both sides and have been leaking grease for a few months now.. I was not aware that it would make the Howling Death whine sound if they are dried out?
Old Oct 14, 2011 | 05:35 PM
deeman101's Avatar
What the....
Old Oct 14, 2011 | 05:46 PM
BoostIsMyDrug's Avatar
Originally Posted by deeman101
What the....
This is exactly what I was thinking... Why do people buy nice cars and neglect the hell out of them?
Old Oct 14, 2011 | 05:48 PM
marcusE's Avatar
Nah.. dont get it twisted.. i just purchased the car from another member when I got back from Korea and moved strait to Kansas after the purchase.... I noticed them the first day I put the car on the lift.. Previous owner neglect.
anyways.. On topic please. I need help.. This is my daily.
Old Oct 14, 2011 | 05:52 PM
forc3 f3d's Avatar
Fix the boots on the axel, check how the t-case fluid looks and refill if needed.
Hopefully you didn't drive around on it too much and do damage to the t-case... Kinda sounds like you ran it a little drive.
Old Oct 14, 2011 | 05:55 PM
marcusE's Avatar
I HAD to drive it to my new duty station 1000 miles.. didnt start making noise until a few days after my drive.. I have to daily it as well.. small miles and granny driving.. Changing fluids tomorrow.
Old Oct 14, 2011 | 06:01 PM
deeman101's Avatar
Yes change all fluids and fix the boots. I'm gonna bet the previous owner never changed the drivetrain fluids.
Old Oct 14, 2011 | 06:13 PM
DJAfterShok's Avatar
That neglect could of just caused you about 1000+ in damages...
Axle boots are cheap to repair. fluid.... maybe 100 max on Tranny and T-case fluid.
Old Oct 14, 2011 | 06:23 PM
marcusE's Avatar
Purchased my Diaqueen LSD gear fluid today for 50 bux for 4 liters.
Not even 100... I'm PRAYING that the Tcase is just low on fluids.
Question : Should I replace the entire axles or just fix the torn CV shaft boots?
Old Oct 14, 2011 | 07:08 PM
barneyb's Avatar
No.
If low then yes. It only holds 0.6 quarts.
May well be toast.
Yes.
Old Oct 14, 2011 | 07:29 PM
marcusE's Avatar
Thank you Barney. I'll post up what I find out tomorrow. Worst case... Team RIP gets to build me one.
Old Oct 14, 2011 | 07:37 PM
forc3 f3d's Avatar
Also, check the axle seal on the t-case!! With the axle popping out it possibly ripped the axle seal which would also cause it to leak even more.
Old Oct 14, 2011 | 07:49 PM
marcusE's Avatar
Will do. not sure what I'll be looking at but I'm sure I'll figure it out tomorrow on the lift.
