My Transfer case leaking? (pics)
Old Oct 20, 2011 | 01:20 PM
itsu's Avatar
So I Just got done with a timing belt job, Im going to drain and refill the transfer case fluid, but it looks to be leaking. Is this from the output shaft?
Old Oct 20, 2011 | 02:41 PM
ProPilot04's Avatar
Hard to tell from the pics, but I'd have to say the leak is definitely from something capable of throwing it everywhere. Like the shaft. Or at least its something dripping it onto the shaft?
Old Oct 20, 2011 | 02:43 PM
italianpryd91's Avatar
check the fluid levels in everything in that area (TFRSCASE, Transmission, Oil on back of valve cover)
Old Oct 20, 2011 | 04:51 PM
itsu's Avatar
Ok I will check the fluid, and look for leaks everywhere I can. Is it possible for it to be over filled, and pushing it out anyway it can? I am at 60K so I can't imagine the seal failing this early, but I guess you never know...
Old Oct 20, 2011 | 05:35 PM
RevMoto's Avatar
My 05 evo leaked from near the axle seal on the transfer case and looked similar to ours just not as bad. Best thing to do is clean it up and watch where it is leaking from.
Old Oct 20, 2011 | 05:42 PM
mine was leaking out of my axle in the transmission and destroyed my literally freshly rebuild trans... then the shop i went after that to get it fixed decided to drain the transfer case fluid and never put it back in... ha
Old Oct 20, 2011 | 09:03 PM
ProPilot04's Avatar
Thats going to slow your lap times down for sure.
JDL Auto Design
For Sale - Wheels / Tires
44
Jan 4, 2013 07:05 AM
JDL Auto Design
Jun 18, 2012 07:51 AM
itsu
Nov 20, 2011 10:54 AM
itsu
18
Oct 31, 2011 09:43 PM
