3 ACD and anti lock light. Help?!
Old Oct 25, 2011 | 07:19 AM
Rotten Egg's Avatar
I was doing some putting around town and at a light my acd lights came on and my anti lock light came on. When car is turned off and back on acd works fine, but anti lock light is always on. Once I get moving for a little bit the acd lights all come on. Car drives and brakes perfectly fine and normal. Anyone have any idea? No clutch or service has been done in 30k miles so it shouldn't be a fluid/bleeding issue.
Old Oct 25, 2011 | 09:58 AM
Rotten Egg's Avatar
No one?
Old Oct 25, 2011 | 10:10 AM
L888Apex's Avatar
Does the car "hiccup" or "hesitate" during partial throttle sometimes?
Old Oct 25, 2011 | 10:27 AM
hamx0r's Avatar
ACD and ABS correspond with each other. I had the same problem when my abs wire got cut when my fender liner decided to go bye bye. So its an ABS issue must likely, either your wire got cut(like mine did) or one of your sensors went bad, etc. check this thread out, it should tell you everything you need to know.. https://www.evolutionm.net/forums/ev...l-pay-you.html
Old Oct 26, 2011 | 11:14 AM
Rotten Egg's Avatar
Thanks for the responses. Car runs just fine, lights just came on outta no where. I'll check my abs wires thanks
Old Oct 26, 2011 | 12:23 PM
frankmc's Avatar
hello, your abs/acd fault can be diagnosed very easy,
abs & acd/ayc fault codes are stored in the acd ecu
use a paper clip to bridge pins 1&4 on the obd plug (on board diagnostics)
with the clip in place turn the key to on don't start the car,
if there is no codes stored the 3 lights will flash continuously,
if there is codes stored
you will get a series of long & short flashes
1 long flash = 10
1 short flash = 1
for example fault code 65,
you would get 6 long flashes followed by 5 short flashes
6x10=60
5x1 =5 =65
there may be more than one code,
hope this helps
Old Oct 26, 2011 | 05:13 PM
Jerry321's Avatar
or a small scan tool
Old Oct 26, 2011 | 05:16 PM
Rotten Egg's Avatar
I have plx wifi in my car to manage my gauges, no code is being thrown
killerpenguin21
Jul 11, 2018 10:41 PM
06redrocket
Nov 18, 2013 02:32 PM
hachansoo0413
May 13, 2012 08:45 AM
06GraphiteEvoIX
Feb 25, 2010 10:38 AM
rgar
Apr 29, 2009 04:53 PM
