HKS cams, how different are they than stock?
Old Jan 8, 2004 | 10:31 AM
alex_alex's Avatar
OK, the title is a bit misleading.
What i want to know is, VISUALLY (aesthetically), how different do the HKS cams look than the stock cams.
Old Jan 8, 2004 | 11:01 AM
ItsStockOfficer's Avatar
Pretty similair...If your making a custom clear valve cover, you won't impress anyone. They do have 272 or what not written on them with a dremel or stamp though...
Old Jan 8, 2004 | 12:15 PM
alex_alex's Avatar
thats not what im asking for. Its more for whether anyone would be able to tell if the cams are stock or not.
Old Jan 8, 2004 | 12:17 PM
SAEVO's Avatar
for the dealer/ warranty
Old Jan 8, 2004 | 12:24 PM
MP5's Avatar
MP5
In Timeout
Yes if they tore down the head they would see HKS engravings. Also any tech worth a salt (2 out of 10) will be able to listen to the car ideling will know it kas cams. I dont have the Vishnu cam idle fix yet so I cant comment on that.
The problem guys is your wrongfully ASSuming that you have a warrenty anyway. I have seen very little evidence of mechanical warrenty for the EVO yet. A few things here and there but I think yall are kidding yourselves
Old Jan 8, 2004 | 12:32 PM
alex_alex's Avatar
Yeah, but if you want to get nitpicky, absence of evidence isn't evidence of absence. Saying that we are "wrongully assuming" is a bit conclusory given that the only thing you are basing that on is the lack of evidence of mechanical warranty (which is spelled with an "a" by the way).
Old Jan 8, 2004 | 12:33 PM
alex_alex's Avatar
And the Vishnu cam idle fix would do absolutely no good if the purpose is to save your warranty, since you would presumably want to take the Xede out as well.
Old Jan 8, 2004 | 12:34 PM
ez76's Avatar
FWIW, just got the the Vishnu XEDEFlash with my 264/272 HKS combo. The difference in idle noise is audible but very slight - a little more aggressive. In my opinion it improves the sound and complements the exhaust.
The Walbro fuel pump is a lot more annoying since its sound is much higher-pitched (~500Hz, like a hair dryer running under your seat) but that's only idling at a stop light with the radio turned down that you notice it.
I wish I had recorded the sounds the car made stock, with cat-back, with dump-back, with gears, and now with cams - it's interesting to hear how the voice changes - right now I am loving the gnarl.
Old Jan 8, 2004 | 12:37 PM
alex_alex's Avatar
why do you have a fuel pump with no turbo upgrade, did Vishnu recommend it?
Old Jan 8, 2004 | 12:38 PM
Eric Lyublinsky's Avatar
Half empty man
Old Jan 8, 2004 | 12:41 PM
Ryanmcd3's Avatar
In Timeout
I would say do the mods, if you don't have 8kish to fix a blown up motor and tranny don't do the mods.
Old Jan 8, 2004 | 12:44 PM
Yep that's what it comes to. You can't afford not to have a warrenty then it might not be a good Idea to mod.
SAEVO's Avatar
so the basic fuel pump upgrade is really that noticeable over stock
Old Jan 8, 2004 | 12:48 PM
MP5's Avatar
MP5
In Timeout
Yea OK alex you got my point. The point is is your kidding yourself If you want to do cams get ready and prepared to take them out if you want warrenty work or dont do them and settle with30 less HP
Old Jan 8, 2004 | 12:56 PM
mprtklr's Avatar
idle on the 264/264 is stock like, you have to really, really, REALLY listen to hear it.
