VIII gsr engine/ fuel trouble
Old Nov 2, 2011 | 05:35 PM
evillilevo's Avatar
Unhappy VIII gsr engine/ fuel trouble
I have an 03 evo 8 gsr with a list of upgrades done to it previously. here recently after having a boost leak and fixing it, pulling the battery, etc. My car is now throwing massive amounts of fuel in the motor. when i drain my oil, it is very thinned and smells of fuel. Also whenever i pull my plugs, they are caked with black. Not to mention black flecks of fuel and smell are coming out my exhaust. And it will hold a rough high idle, 1500-2000 rpm. I am curious if i will need to check if i have a problem inside the motor such as a piston ring. Or if it is a turbo based issue where its getting lack of air. not to mention my Resurge valve is letting boost out when im on the throttle.
aftermarket parts:
hks 264 cams
walbro 255 fuel pump
ported stock 9.8 turbo
ebay header
buschur bfmic kit w/ lower ic piping
3 in o2 piping
3 buschur straight pipe exhaust (no cat)
aem wideband O2 sensor
aem turbo timer
greddy kevlar timing belt
Old Nov 3, 2011 | 11:50 AM
bevolucion's Avatar
what is your wide band saying, and simple test like compression test would be the first thing you should do. may be with some more info you can get better answers in here, like high fuel at idle or WOT? things of that nature. Good luck
