Can I disable the Immobiliser
Old Jan 8, 2004 | 08:38 PM
Rallyman's Avatar
Is it possible to disable the immobiliser fitted to my car so that i can install a programmable ECU that does not have an immobilier capability ?
Old Jan 8, 2004 | 09:00 PM
YellwTyper's Avatar
Sounds suspicious... someone wants to steal a car?
Old Jan 8, 2004 | 09:07 PM
Creamo3's Avatar
Don't know about the imobilizer question, but wanted to throw a shout to my peeps out in Trinidad my best friend is from there and has a bunch of family out there
Old Jan 8, 2004 | 09:12 PM
Alfriedesq's Avatar
If you install a NON imobilizer ecu then the car runs fine - no issue
You just cant install another imobilizer equiped ecu
Old Jan 9, 2004 | 12:00 AM
Fourdoor's Avatar
So the AEM EMS becomes the perfect theft device..... pop the door key hole, rip out stock ECU and plug in EMS...hotwire and drive away
Keith
Old Jan 9, 2004 | 02:55 AM
Rallyman's Avatar
It is not correct to say if you replace the ECU the car runs fine - in fact the car does not run at all unless an ECU with the immobiliser code is installed. Most aftermarket ECUs for Evos such as the Haltech, Autronic and GEMS do not provide for the new immobiliser function.
We are trying to install a GEMS ECU in a car being converted for rallying and are looking for the easiest way to address this issue whilst retaining the standard ignition key.
TomEvoX
Australian Forum
Jun 22, 2015 01:21 AM
evonut270
26
Apr 4, 2013 12:00 PM
acsian
Dec 8, 2009 07:13 PM
jimmy79
May 19, 2008 04:33 AM
vtec70
Jul 11, 2003 10:31 AM
