QM Twin Installed Loud Noise
Old Nov 3, 2011 | 04:42 PM
psphinx81's Avatar
i must be semi deaf , i turned up my volume and heard what others are talking about. i would highly suggest pulling the tranny and figuring out whats wrong
Old Nov 3, 2011 | 06:03 PM
03whitegsr's Avatar
From one QM owner to another, the QM is loud, but not that loud.
Sounds like you are over-extending it or something. Looks like the clutch dis-engages and then 2" more of pedal travel you start getting the noise?
Does it make the same noise if you push the pedal down just enough to get it in gear but not all the way to the floor?
Old Nov 3, 2011 | 07:28 PM
bostonhatcher's Avatar
Sounds like you have a bit of thrust bearing wear and when you push the clutch in the flywheel is scraping the starter plate or the clutch cover that bolts to the bellhousing by the oil pan.
Old Nov 3, 2011 | 09:17 PM
S13 Curtis's Avatar
No it's not so bad when it's just enough to get it in. I'm going to adjust it now that you pointed that out.
