QM Twin Installed Loud Noise
Old Nov 3, 2011 | 04:34 AM
S13 Curtis's Avatar
So i had a QM twin installed (Old Black version) and drives fine but Every time I press the clutch pedal in it makes an awful screeching noise and its very loud . Once I start to ease off of the pedal and as soon as it starts to engage the noise immediately stops. When in gear there is no noise, only when the pedal is pressed. Help Please!!!!! Thanks
EDIT: Heres the vid. It dosent sound normal to me.
http://youtu.be/h1h3dZRe05s
-Curtis
Old Nov 3, 2011 | 04:49 AM
Toddevo 8's Avatar
that is normal on a twin disk clutch, my made a noise two, I dont think it was that loud though.
Old Nov 3, 2011 | 05:17 AM
S13 Curtis's Avatar
Im going to try and make a video for you guys.
Old Nov 3, 2011 | 05:22 AM
mrboost05's Avatar
its normal for that clutch there is really no way of getting around the noise you are also not going to get very many miles out of it but its a great clutch and will hold a ton of power.
Old Nov 3, 2011 | 12:43 PM
S13 Curtis's Avatar
Video Posted. There's No way thats normal it sounds awful.
Old Nov 3, 2011 | 01:04 PM
localtoys73's Avatar
100 % normal. I have 2 friends with the same clutch it sounds exactly the same. I make fun of them because my tripple is quiet if compared.
Old Nov 3, 2011 | 01:10 PM
white4g63's Avatar
I am running a corbonetics twin disk and it has the same sound. It makes sounds at a dead stop with clutch pushed in, and when decelerating. While engaged and cruising it it quiet as can be.
BenJ's Avatar
Sounds normal. Just be sure that your clutch is properly adjusted to prevent damaging the htob and pressure plate.
Old Nov 3, 2011 | 01:13 PM
WHTEVO's Avatar
I have the same clutch. Mine doesn't squeal when pushing in the clutch, but the chatter is pretty much just like mine. I have had two of these clutches, both of them sounded the same, so it is normal.
If you researched before you bought that clutch, you'd see plenty of people say it is louder than most.
Aaron
Old Nov 3, 2011 | 01:25 PM
awdturbo8's Avatar
My twin QM sounds nothing like yours. Your is very Loud. That doesn't sound normal to me
Old Nov 3, 2011 | 01:30 PM
_des_'s Avatar
That is not normal.....I had a QT also and it didn't sound like that.
https://www.evolutionm.net/forums/ev...-included.html
I'm having what seems like the same sound coming from my Exedy twin with ams push type conversion
Still running strong so I haven't dropped the transmission to check it out.
Old Nov 3, 2011 | 01:34 PM
psphinx81's Avatar
its that loud because he is in an enclosed area.. sounds normal to me, i had the same exact clutch
Old Nov 3, 2011 | 02:32 PM
awdturbo8's Avatar
The binding clunking noise when he barely presses the pedal in a bit
Isn't normal at all
Old Nov 3, 2011 | 02:40 PM
browningderek's Avatar
NAW man! That is not normal! You got some metal on metal action goin on in there. When you push the clutch in all you should hear is a slight bearing noise which is the throw out bearing spinning. If you really feel it sounds like hell then you need to take it apart and find out whats up. Sounds to me like the throw out bearing is bad or something is wrong with the clutch.Sorry for the bad news, pulling the tranny is a tough job.
Old Nov 3, 2011 | 04:40 PM
S13 Curtis's Avatar
Dude some times the shifter will vibrate with the scraping noise and its loud even while driving, its even worse between shifts when the rpm was high. It cant be normal...
