At wits end with spark plugs and P0300
Old Nov 10, 2011 | 06:59 AM
evo 9 guy's Avatar
I was just dealing with this and it was completely tuning related. Follow what the others have said and get/check your tune, or don't ask for help if your not going to listen.
Old Nov 10, 2011 | 07:10 AM
FX11's Avatar
+1 to this
Old Nov 10, 2011 | 07:16 AM
danameisoj's Avatar
my p0300 is diabled in my rom.. and my cel is still on for p0300. lol
I just learned to rock my cel. my gsc s2's and exedy twin dont help the code either
Old Nov 10, 2011 | 07:22 AM
Ralliartize It's Avatar
Originally Posted by wingless
So you ask for advice, get an answer and decide to continue doing what has not been working? GL.
I'm not trying to be hard headed by any means. Just trying to garner as much information on this issue before I have to throw done 500 bones on a new tune.
I apologize if I come across as stubborn.
Old Nov 10, 2011 | 07:59 AM
danameisoj's Avatar
it could be completely unrealated to the tune. some roms are just very picky.
I never had the code until i swapped my gsc cams in .. my code trips at idle because of how hard it cams out .
His hks are mild cams but the rom can just be sensitive to the "misfire" from cams.
Old Nov 10, 2011 | 08:42 AM
gsrboi80's Avatar
Not possible either
1 It was not properly disabled
2 Code was not cleared after disabling it
Chances are the timing portion in the Ignition map is too far advanced causing the code. Sorry not familiar with the terms "cams out'. Is that like hellaflush
Old Nov 10, 2011 | 08:53 AM
4xforce's Avatar
Take the easy route first. Re-gap your plugs. My car ran like crap on anything more than .022.
Old Nov 10, 2011 | 09:25 AM
mt057's Avatar
People post up about this code constantly. It is nothing new. A quick search brings up a ton of info.
If you have an evo 8 of any year it is a pretty common problem. The patch was made up by some very smart individuals who had the problem as well. I could not tune out the problem so I simply disabled it years ago.
I used to get it every 30 seconds or less while cruising. I had no mechanical issues.
If you have a taxtric cable I could walk you through it. If you do not have one. I would buy one. It is extremely helpful to have in general when dealing with the ecu.
Good luck, don't make things too hard on yourself...
Old Nov 10, 2011 | 09:32 AM
I did search and am aware that there's a ton of threads on this...but I was really alarmed when the car ran bad with new OEM plugs, I was wondering if something else bigger was the culprit.
Old Nov 10, 2011 | 09:47 AM
Wheatley's Avatar
Originally Posted by gsrboi80
0008 ROM is what they left the factory with. Don't spend money on any other ignition related components man. I would get it on a 0015 ROM and have your fuel and ignition tables tuned correctly, your ignition map prob looks like this:
88888888888888888888888888888888888888888888888888 88888888888888888888888888888888888888888888888888 88888888888888888888888888888888888888888888888888 88888888888888888888888888888888888888888888888888 88888888888888888888888888888888888888888888888888 88888888888888888888888888888888888888888888888888 88888888888888888888888888888888888888888888888888 8888888888888888888888888888888888888888
From there if the issue still remains disable the code routine.
block of 8's lolz. Race gas timing map bro
Old Nov 10, 2011 | 10:38 AM
JohnBradley's Avatar
New plug wires? Does it feel like it ACTUALLY is missing or it just throws the code. Gap to 0.020, what clutch?
Aaron
Old Nov 10, 2011 | 10:52 AM
Aaron
Plug wires are the original ones. When it throws the code the runs like crap..so in my case it's not a phantom P0300. Clutch is an Exedy Twin disk.
Old Nov 10, 2011 | 10:57 AM
surferjeff's Avatar
Turn off the periphery bit in the ecu for that code.
Old Nov 10, 2011 | 11:08 AM
Main culprit.
Second is most likely the wires themselves. They always run like crap when the P0300 gets thrown, there is some limp map that it will refer to (or low octane maps for that matter).
I would change the wires and have the P0300 disabled. Send me your ROM and I can get it taken care of if you have a cable.
Aaron
Old Nov 10, 2011 | 11:18 AM
Aaron thank you for the offer. Sadly I the tactrix 1.3D cable which is just the datalogger only cable. At this moment in time I have no way of pulling my map. In the interim i will take your advice and order new plug wires.
