intake install went wrong
Old Nov 9, 2011 | 07:55 PM
Chaser_41's Avatar
So long story short, my friend was messing around with my stock EVO 8 BPV and broke off the breather nipple !!!! I'm freaking out. I super glued it back on and used this high grade putty that can be used on plastic for support.... My question is.... How bad is this ? And what can go wrong if per say before I can replace it, it snaps off again...
Old Nov 9, 2011 | 08:05 PM
binky's Avatar
If it breaks off, you run the risk of not releasing the pressure in the intercooler piping after you boost. It could damage your turbo due to surging.
*EDIT*
Do you mean the blow off valve/bypass valve, or the boost control solenoid like wizzo said? Good call wizzo, I read it quickly and thought it said BOV.
-Bink
Old Nov 9, 2011 | 08:06 PM
wizzo 8's Avatar
BPV as in the boost control solenoid? If so and the nipple from the valve to the intake tube broke its not that bad since its not under pressure. If its the one that goes to the wastegate then thats very bad and I would stay out of boost until you replace it.
Old Nov 9, 2011 | 08:30 PM
eponti's Avatar
I think he is talking about the plastic nipple in the intake pipe.
Old Nov 9, 2011 | 08:35 PM
wizzo 8's Avatar
If so I wouldn't sweat it then. The glue should hold since there is no pressure there. If it does break off you may get a check engine light for mixture too lean because of the unmetered air coming though that broken nipple. Your gas mileage may also get worse with it broken off.
Old Nov 9, 2011 | 09:45 PM
Chaser_41's Avatar
No, im referring to the actual PLASTIC blow off valve(bypass valve, whatever the F*** you want to call it). Theres the part that connects to the intake pipe, and the part that connects to the big rubber hose going to the UICP. and the part im talking about is a little breather nipple that goes from the BOV/BPV to the intake manifold....
AND UPDATE, finishing install of intake, went to put the breather hose on the mended breather nipple and it broke off the BOV again. So, im ****ed.
Old Nov 9, 2011 | 09:54 PM
D Grade's Avatar
Youre gonna need another BOV. Without vacuum, the BOV won't open and do its job when the throttle is released. Plug the vacuum line going to the BOV, buy a new BOV, and stay out of boost until the new BOV is there and on the car.
Old Nov 9, 2011 | 09:59 PM
wizzo 8's Avatar
Get a metal Evo 9 BOV if possible. Holds boost a lot better.
Old Nov 9, 2011 | 10:19 PM
project_skyline's Avatar
Please for the love of god get a new bov, the stock 8 bov has proven to leak at a mere 1 psi. Do yourself and the car a favor and get a evo 9 bov or something else. APS, cobb, syncronic.
Old Nov 9, 2011 | 10:43 PM
Chaser_41's Avatar
Yeah this is what I figured. Oh well. Damn owning an EVO is expensive Haha !
Old Nov 9, 2011 | 11:22 PM
sujinX's Avatar
well sooner or later you should be replacing the plastic evo8 d/v with a metal evo9 one anyways. soooo just look on the brighter side, now u have to get one and its better for you anyways.
good thing theres a ton in the f/s section on the forum. dont pay over 85 shipped, theres a ton. and those for higher are just raping for money. i got mine for 75 shipped MINT on here.
Old Nov 9, 2011 | 11:26 PM
EV0L-IX-MR's Avatar
There's a guy on here selling a Evo 9 bov for $25. I'll try to get you the link
Old Nov 9, 2011 | 11:36 PM
sparky's Avatar
Wow, deja vu! The same thing happened to me. Get a metal IX DV as others have suggested.
Old Nov 10, 2011 | 12:06 AM
Chaser_41's Avatar
Thanks for the help guys
Old Nov 10, 2011 | 02:44 PM
Chaser_41's Avatar
Haha! Great, I feel better now knowing im not the only one that f'ed this simple install up.
