Twin Scroll divider melted in GT35 housing...
I've heard you still get some benefit using a divided manifold and an undivided housing. Kind of like a mild tri-y header affect.
Which single scroll A/R you going to toss on?
I'm not sure if the car will be ready for the track this weekend though, engine/gearbox needs to go in then it needs to be retuned/checked on the dyno for the single scroll housing and the reassembled engine.
I'm not going to potentially **** off ATP when we are hoping to get warranty out of them
EGT Sensors are on the cards, and i might try to talk them into Exhaust pressure sensors too for testing.
The housing in question is a 1.06 T3 TS housing from ATP for a GT35.
Answer from ATP Turbo, i put it in the first post as well
Here is the answer from ATPTurbo
"Tell your customer we are working on a stronger unit that can endure circuit racing to extended periods of time without fatiquing that way.
There is stronger material available now for turbine housings, but not in the divided (twinscroll) application that the customer is running.
There is an upcoming release of Garrett's twinscroll v-band housing that will use a stronger casting material but that is 1/2 year away.
If he has to be up and running NOW, going to the 1.06 A/R housing will give him some more strength because that unit has more wall thickness, but it's still not a 100% guarantee due to the stresses of circuit racing.
Please pass this along to your customer.
Thank you."
"Looking at the dates below, he's out of the 12 month warranty period unfortunately.
We are working on a stronger housing for the future so that he has something that will hold up forever on circuit racing though."
To sum it up, current twin scroll exhaust housings are not and were never designed for circuit racing.
beware to anyone using them.
We have had another GT30 Exhaust housing crack through the divider also. This was on a drift car.
I'm wondering if T4 Twin scroll housings would hold up any better?
Thank you."
We'll see if we can melt the stainless steel twin scroll housing lol.
The Subaru is still in the development phase, we are using a stock short block, so max power was set to 300kw. flick me a PM if you would like graphs, i'm happy to share.
Once we build the 2.5litre up for it over the xmas break, we'll put it on kill mode.
Carl is a big fan on larger turbo's with less boost though, so dont expect 40psi or anything crazy like that lol.
The most i've ever seen him push is 36psi on Han's SR20, and that netted 520kwatw. Not bad for a plan GT3582.
More info...
One of the external wastegates were jammed open.
The housing is "warped" in the direction of the open wastegate runners.
So the housing has differential pressure across the twin scroll divider in the housing, possibly causing it to push the divider over.
It's a reasonable explanation for what we have seen.
